Question about Injection Pump
Old Feb 16, 2011 | 03:45 PM
tootall5764's Avatar
tootall5764
I have a 93 F-250 with a 7.3 that has a Banks turbo. My question is, when I am pulling a hill or heavy load my pyrometer only goes up to around 450 degrees and 14 psi boost. Shouldn't I have higher temps pulling a load? Will increasing the pump pressure help with this. Also, I get almost no smoke ever, even when it starts. Could the timing be off as well?
Old Feb 16, 2011 | 04:04 PM
1994F2507.3L's Avatar
1994F2507.3L
where is your pyro probe located? and 14 lbs of boost is getting near the danger zone so i would be pretty comfortable right there or near 10psi actually. smoke is unburnt fuel and is bad actually so if your maintaining speed and not ******* to terribly i would be pretty happy with where your at.
it sounds to me like your EGT's are a little low but we will need to know where your probe is located.
Old Feb 16, 2011 | 05:53 PM
tootall5764
I am not sure where the probe is I'll have to find it. Where are they usually put?
Old Feb 16, 2011 | 05:55 PM
wreckinball's Avatar
wreckinball
manifold or crossover pipe, if you have the old style box turbo, it will be in the turbo pedestal right before the turbo, i dont know if the sidewinder has the same location.
Old Feb 16, 2011 | 06:17 PM
tootall5764
It is right before the turbo.
bwise
Sep 7, 2010 06:51 PM
DAI532
27
Sep 24, 2009 08:34 PM
icrman
Jan 24, 2008 07:15 PM
dalkins1
Jun 16, 2007 07:39 AM
bkeese
Sep 5, 2006 10:34 AM
