Have you already tried everything available in the Hydra library for your hex code and none work? What upgrades do you have that the canned tunes won't work? Have you reached out to any of the professional tuners?
i had received jelibuilt tunes a few years ago, but also been chasing a problem. Think it’s tune related. Long story short when the TC locks my truck loses and Boggs down. Have essentially put a lot of new parts and still does it. It’s Been at a shop for like a month now, thinking it’s a tune problem. Other than that there are zero problems or codes.
So did the tuned you have work at one time and were written for the upgrades you've listed, the major ones at least? If the tunes did work at one time and no major changes have been made I'm not sure how a tune would go "bad". It's just data, nothing to go bad. No moving parts and indefinite shelf life.. The chip can fail but not sure it could in such a way as to cause such a specific issue. Have you tried dumping the files on the chip and reloading the originals?
To be honest couldn’t tell you if they worked fully or ever noticed the bogging down. After getting the tunes, never really drove the truck long enough. Barely have driven it the last 3 years. The only thing that wasn’t included when I had the tunes, was the new idm 140v, new pcm and the stage 2 transmission. Haven’t tried anything with the chip, not really sure how to do that.
why I’m on here to see if someone that knows can get me tunes for my truck.
I had paid for custom and couldn’t tell you the difference. But to me they seem like generic tunes. “ 01 - Local File: TNAA42_30N_ MODIFIEDSTOCK-EMISSIONS.hcf
Those 2 pcm numbers should use the same tunes so I don't believe that's your issue. Judging by the tune files they seem like correct tunes for the 30n which would be 30% nozzles which you have. I would try to reload the tunes onto the hydra an make sure pcm is cleaner well where the hydra connects.
the pcm pins are clean, made sure of it. How would I reload tunes, when they were put on by the shop I bought the hydra from. I don’t have the files. The most major upgrade I recently did was the transmission. I’m not a diesel expert but maybe TC stall speed?
If there jelibuilt tunes I would contact them and ask for there opinion and see what they say. The tunes they write control tranmission parameters as well.
