Napa filter cover
Old 04-27-2014, 09:32 AM
roostonu's Avatar
roostonu
roostonu is offline
Napa filter cover
Sorry for not searching but I'm on my phone with no wifi. I just drained my oil and pulled the filter. I bought a motor craft filter but just discovered I have a Napa cover with an extended filter. Can I use the short OE filter with the Napa cover?
Thanks
Old 04-27-2014, 09:36 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Get a new one ASAP
Old 04-27-2014, 09:53 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Negative, do not mix and match.
A Napa filter with the Napa cap would be leaps and bounds better than a filter/cap that don't even come close to fitting. Get an OEM cap asap, but run the closest to actually fitting combination that you can in the mean time.
Old 04-27-2014, 06:34 PM
Lou Braun's Avatar
Lou Braun
Lou Braun is offline
If you can't find an OEM cap right away, I'd just put the old filter back in until the correct cap was purchased.
A short filter in a tall cap is a problem combination.
Lou Braun
Old 04-27-2014, 08:20 PM
luv2brode's Avatar
luv2brode
luv2brode is offline
had this issue with my new to me truck, got the filters bought changed oil pulled old filter and found out it was a napa. put old filter set up back in hunted down correct cap and changed asap. also took a paint marker and wrote do not discard on it for future reference
Old 04-27-2014, 08:40 PM
Lx460's Avatar
Lx460
Lx460 is offline
The napa filter/cap is glued/bonded together anyways...just get a new ford cap or put the old napa setup in until you can get the right cap.
Old 04-27-2014, 08:46 PM
roostonu's Avatar
roostonu
roostonu is offline
Thanks for the responses. I ended up picking up a Wix filter/cover combo. I was limited since it is Sunday and I really didn't want to reuse the old filter.
Old 04-27-2014, 09:14 PM
Splash67's Avatar
Splash67
Splash67 is offline
I hope you're just intending that as a stop gap...I'd get as correct size cap ASAP...I actually changed to a Sinister cap with the extra external filter...IMHO
<a href="http://s842.photobucket.com/user/Splash67/media/Monster%20-%20March_April%202014/IMG_20140423_233449_584.jpg.html" target="_blank"><img src="http://i842.photobucket.com/albums/zz342/Splash67/Monster%20-%20March_April%202014/IMG_20140423_233449_584.jpg" border="0" alt=" photo IMG_20140423_233449_584.jpg"/></a>
Old 04-28-2014, 12:15 AM
04badford's Avatar
04badford
04badford is offline
In the Future Walmart carrys are OEM filters, so does Tractor supply, Get that wix filter ( out) before it falls apart
Old 04-28-2014, 01:11 AM
Splash67's Avatar
Splash67
Splash67 is offline
This is my oil cooler screen after I let someone else do an oil change and they put in the Wix filter/cover...I'm guessing that some of that stuff is from the CCV filter.
Old 04-28-2014, 07:26 AM
roostonu's Avatar
roostonu
roostonu is offline
Oh great just what I need. Thanks again for the help.
Old 04-28-2014, 08:54 AM
Splash67's Avatar
Splash67
Splash67 is offline
Sorry...we're not all as fatalistic as it might sound. We just like to do our best to keep others from possibly repeating mistakes that others on FTE (me included) have made in the past.
Old 04-28-2014, 01:04 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
What's a CCV filter and how does that end up on the HPOP screen?
Josh
Old 04-28-2014, 03:08 PM
Splash67's Avatar
Splash67
Splash67 is offline
Josh
Inside the driver's side valve cover there is a filter that the CCV line snaps into on my truck. The inside filter material looks and feels like steel wool. The filter material was coming out of the side of the filter. I found the material inside the rocker carrier, inside the oil filter housing, and since the wix filter assembly didn't seat all the way down I also found it inside the cooler sump area, and clogging the screen.
For the time being I've removed all of the filter material from the inside of the valve cover and I'm planning to check the oil filter again in about 100 miles. I'd like to get a CCV re-route mod done soon...time and money are holding me up at the moment.
Fortunately, it's not actually steel wool, because I didn't find any of it stuck to the magnet of the oil drain plug.
TobiasR.
18
03-03-2011 06:00 PM
bhd
6.4L Power Stroke Diesel
15
03-23-2010 10:26 PM
todd230
11-04-2007 02:26 PM
TJ Shaw
06-14-2007 09:08 PM
Mindstream
01-08-2007 03:26 PM
Quick Reply: Napa filter cover
