I have a problem with my new fuel filter ..
I bought a new one from Fram, and at this Filter the Cover and Filter are one and that is the Problem. At Rockauto I can buy only a Fuel Filter which comes into the old Black Cover.
I need help to remove the new fuel filter from the new cover, because I have tightened it to strong so it have become a crack
You can't take the cap off that filter. Either get the filter without the cap and use your old cap, or get a new filter with the cap on. I have had the filter with the cap leak a couple times, now I will only use the filter without the cap built on.
If you need a new cover spend a few extra dollars and get a billet cover. Don't remember the names but a couple of places make a better cover out of aluminum - best part about these is they have a nut pattern machined into the top. Much easier to get off than the stock cover.
Just forund that, Dan at Midwest Transmissions, makes the billet ones also, at 70 buks, but also looks like theres a plug atop for a fuel pres. gauge for it...just emailed him regarding it.
