Muffler
Apr 27, 2014 | 07:31 PM
Muffler
Might be a dumb question, but I don't know the answer since I am new to the diesel world. Can you put a flowmaster exhaust on a diesel truck?
Apr 27, 2014 | 07:51 PM
Sure. I don't know if they have a kit, but if you can find one with the right inlet and outlet size and the right length, you should be golden.
Apr 27, 2014 | 08:00 PM
Just straight pipe it. Unless you have the 2003 turbo it won't be loud at all.
Thad
Apr 27, 2014 | 08:17 PM
Quote:
Originally Posted by
dakotajeep
Thad
No joke, unless your somewhere where a loud exhaust can get you ticketed, I'd just straight pipe it.
That's what I did. Nice rumble sound, then turbo whistle, then exceedingly loud when your hot ******* it.
ETA: I bought an aluminized steel straight pipe kit from AFE. It's the AFE Atlas system, comes with 3.5" down pipe, then bellows out to 4".
Apr 27, 2014 | 08:18 PM
I have a 2004 f250 6.0 so do I even need a muffler, or can I cut the exhaust off at the cat
Apr 27, 2014 | 08:24 PM
tcjhkbjt
Before I put my exhaust on, me and a friend cut the exhaust off before the cat. It was loud and poppy and sounded terrible.
After piping it out the back like factory, its not loud in the cab at all.
Apr 27, 2014 | 08:37 PM
tcjhkbjt
Probably depends on your state. I would look into it before you get too bold and start cutting!
Thad
Apr 27, 2014 | 08:45 PM
dakotajeep
Thad
Yup if your states doesn't do smog checks I would ditch the cat also.
Apr 27, 2014 | 08:51 PM
6.0 sounds better with nothing between the tailpipe and turbo
Sent from my Telegraph using IB AutoGroup
Apr 27, 2014 | 08:52 PM
I am in Texas and I don't think they do a smog check when I take it in for inspection. So I can just run straight pipe all the back, no cat or muffler???
Apr 27, 2014 | 10:14 PM
Apr 27, 2014 | 11:25 PM
tcjhkbjt
Texas emissions laws are exempt for diesel equipped vehicles. Only a safety inspection required.
That being said, you can be ticketed in Texas for excessive exhaust smoke if your tailpipe smoke doesn't clear after 10 seconds.
Apr 28, 2014 | 01:40 PM
KIDkiser
Maybe, but if you do that, hold on to the cat. They're not cheap and you never know when you might move to a state or city that requires one.
Apr 28, 2014 | 02:26 PM
tcjhkbjt
My wife just recently bought an 04 F-250 6.0 and it had the exhaust cut off right before the cat. Sounded like **** and ran even worse (not to mention the underside covered in black soot and a filthy mess to work on). I took the stock exhaust system my son in law had cut off his 06, TIG welded it back together and hung it on my wife's 04, sounds normal now and runs much better IMHO.
Apr 28, 2014 | 03:56 PM
Coronado
i did the same, except it sounded awesome
f350powerhouse
Aug 26, 2009 09:52 AM
greaseburner
Jan 5, 2009 10:11 AM
MG86TA
Feb 10, 2006 07:52 PM
mpbpulaski
29
Nov 7, 2004 07:50 PM
Starratt04
Dec 4, 2002 05:05 PM
