Torqshift slipping in reverse
Lately I've noticed a shudder when I try to accelerate in reverse. Other then that the trans has been shifting and operating fine. If I put in in reverse and let it idle or give it a little it will back up fine, but if it's a decent hill, or I have a trailer I end up feathering the throttle to keep it from slipping. I would describe the "slipping feeling" as a feeling of pump cavitation on a hydraulic drive.
I change the fluid and filter every 25k since I got it, but the trans filter is black every time I change it out even though the fluid always looks good. I'm 4k away from crossing the 250k mark on the truck. So is it time for a rebuild or does it just sound like a solenoid acting up or something else minor?
This symptom is known as reverse chatter, feels like you didn't get it all the way into Reverse.
The solution is to replace 1 of the solenoids in the transmission with a GoGO Diesel or Stock ECP Sol as this controls the 3-5 shift and Rev.
It's easy to do I did mine in 30 minutes.... But may not solve your problem if it's been doing for long -you'll need to replace the clutches associated with the Rev gears.
Procedure...
Drop Pan remove fake filter housing and o-ring if it hangs up in the tube.
a few screws to hold the harness
remove the circlip off Sol #3 or 6 can't remember
there are 2 rows 4 in 1 and 3 in the other.
slide out sol.
slide in new sol - only goes in 1 way
replace circlip
replace screws
Now....
While your in there...
You should've ordered the 08 pan and true filter from the online parts guru
D
Here is a thread on another forum ...........
G2shuck modified dd solenoid review - Ford Powerstroke Diesel Forum
Go go? Or modified EPC solenoid?? - Ford Powerstroke Diesel Forum
Denny
Procedure...
slide out sol.
replace circlip
replace screws
Now....
D
Denny
Hasn't been doing it long, I just noticed it this weekend. I had to feather the throttle in reverse backing up my boat on flat ground and backing the truck unloaded up my driveway. I'll look into the Direct Solenoid based off those posts. If nothing else it might by me some time on the current trans. Thanks for the help.
Well, I got the HD version of the solenoid in there yesterday after work... still have the slipping in reverse. I barely go the truck backed up the driveway after the test drive. So I'm assuming my clutches are toast and I need a rebuild if it won't hold with 4x the previous holding power...
Luckily I found a Ford mechanic in the area that rebuilds torqshifts on the side who has a rebuilt unit with a new torque converter for a good price, so I'm going to pick it up this weekend and try and find an open weekend to switch them out.
Well, picked up the reman trans last weekend along with a torque converter. Planning on doing the swap this weekend. I'm also going to transfer the HD Direct solenoid I just installed into the current trans and add an HD EPC Solenoid to the "new" one.
HD EPC Solenoid
03-up 5R110 HD EPC Solenoid Heavy Duty Application
HD EPC Solenoid
Reman trans with upgraded solenoids is in. Preliminary test drive went well. Found out why my trans has had an annoying leak I couldn't track down for at least the last 50k also, but I'll keep you all in suspense till I have more time to post pictures... I'm still covered in atf and dirt and need some sleep.
Although I have ZERO knowledge of things automatic transmission related, what I do know is, it seems that these particular transmissions were prone to have the reverse clutch drum snap ring "walk" out of the case groove to cause the damage as seen in the photo above, only in model years between late 2004 and early 2005. Ditto for the odd TFT sensor failure, again only on 2004 and 2005 model years. Aside from that, they have been almost completely trouble free.
Yes, I knew about the snap ring thing popping out in the 2005 year range. I think Ford even put a TSB out for "snow plow" specific trucks on it also. Everything I saw about it showed it wearing a hole in the passenger side of the case though, not the top. It does appear to be in the same "plane" as where the holes normally appear in the side of the case, so I'm sure that's what it was. The crazy thing is I've been trying to track down that leak for the last 50k. I'm amazed it took this long for other problems to show up. I was loosing less than a quart a month and putting 15k miles on it a year...
KAT_Ayanami
03-08-2022 06:04 PM
95F150RLP
07-07-2017 05:00 PM
RadioControlGuy85
01-30-2016 03:25 PM
