stalls out in reverse
Old Jan 27, 2016 | 01:24 PM
RadioControlGuy85's Avatar
RadioControlGuy85
have a 92 f150 with a e4od with od on the shifter handle.
just did a transmission fluid change and now the truck will stall out in reverse.
anyone got any idea?
Old Jan 27, 2016 | 03:02 PM
dixie460's Avatar
dixie460
Pretty sure that can happen if you're low on trans oil. Check with the truck level. Transmission warm and engine running. Shift into each position starting and ending in park before you check it. That is the correct procedure any time you need to check it.
Old Jan 27, 2016 | 03:09 PM
RadioControlGuy85
we got a gallon out when we drain it. and we put a gallon back in.
now it will stall in 1st and 2nd.
if you go from park to drive its ok. park to reverse its ok. but if you go from 1st or 2nd to reverse it will die.
could it really be low on trans fluid?
Old Jan 27, 2016 | 03:34 PM
chrismd188's Avatar
chrismd188
Sounds like the filter might have fell down,did the old o ring off the old filter come out with it
Old Jan 27, 2016 | 03:39 PM
Ron94150's Avatar
Ron94150
Only you can answer that, by checking the dip stick. Dixie 460 gave you the correct procedure, but to clarify what he he said, you leave the engine running to check the transmission fluid.(sorry Dixie 460, someone that doesn't know, may shut the truck back off after going through the gears). Anytime you do any fluid swap, don't just try to match what you poured out, always check the level.
Old Jan 27, 2016 | 05:08 PM
RIKIL's Avatar
RIKIL
this happened to me a while back..when the trans was low on fluid it would stall going into reverse
Old Jan 27, 2016 | 05:46 PM
rla2005's Avatar
rla2005
You barely drained the pan.....a complete fluid change takes 16+ quarts. You wasted your time by only draining the pan. Mark Kovalsky has a great write-up for the proper procedure.
https://www.ford-trucks.com/articles...-transmission/
Old Jan 29, 2016 | 04:54 PM
RadioControlGuy85
Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
didnt have the time or money to do the complete change,
Old Jan 30, 2016 | 08:54 AM
Philster's Avatar
Philster
I had the same problem stalling in reverse. I also read somewhere on one of the truck boards, if the engine stalls in low 1 and reverse it is most likely the transmission filter has fallen down into the pan. My truck stalled in both gears. I dropped the pan and the filter came down with the pan. I purchased a motorcraft filter and made sure I installed with the o ring and pushed up into hole. Problem solved.
Old Jan 30, 2016 | 03:25 PM
RadioControlGuy85
we got it fixed, was low on oil.
KAT_Ayanami
Mar 8, 2022 06:04 PM
chrison600
Oct 13, 2012 12:56 PM
tbart16
Feb 1, 2010 11:31 AM
boonie
Feb 13, 2007 06:01 PM
FLgargoyle
Jul 20, 2006 12:15 AM
