E4OD hard/delayed shift into reverse
Old Jul 2, 2017 | 09:19 PM
95F150RLP's Avatar
95F150RLP
1995 Ford F150 5.8L 4x4 EB 389,000 Mile's. Owner since 2001. Religious maintenance schedule I do myself. Literally over night started shifting hard into reverse. Trans fluid/filter resent service. Fluid level good. U joints good. Trans mount good. Differential good. Engine RPM good. No codes. Had the miss's put the truck in reverse while I laid underneath and watched... MLPS - linkage - shifts into reverse, watch the slip yoke movement and it's almost as if the trans is searching then BAMM, into reverse. Any thoughts???
Last edited by 95F150RLP; Jul 2, 2017 at 09:33 PM. Reason: Adding more information
Old Jul 7, 2017 | 09:44 AM
rla2005's Avatar
rla2005
Sorry to say this but you mentioned "Trans fluid/filter resent service". There is a current thread on the topic of transmission filters. They are known to drop which causes a hard reverse shift and/or engine stalling.
The simple test is to drop the pan then inspect the filter to see if it has become dislodged or completely dropped into the pan. There is a filter clip available to prevent this from happening.
Here is the thread: https://www.ford-trucks.com/forums/1...ilter-fit.html
Old Jul 7, 2017 | 09:52 AM
95F150RLP's Avatar
95F150RLP
Did that
I did check the filter to see if it drop. That was the recent fluid/filter change. Never had that problem though.
Old Jul 7, 2017 | 05:00 PM
rla2005's Avatar
rla2005
Just thought I would point that out. There are other transmission experts here that can help.
mtnmx
Feb 22, 2017 11:25 AM
ronwarepctech
Nov 19, 2016 11:31 PM
RadioControlGuy85
Jan 30, 2016 03:25 PM
Kert0307
Jul 1, 2013 03:59 PM
IDIDieselJohn
Jan 21, 2011 05:11 PM
