Towing mirror conversion
I love my no-nonsense 2006 F250 with almost no options, but sometimes I do wish that I had heated power mirrors. I have the little stock mirrors and seeing around a 7 ft. wide trailer is a bit of a challenge. Also they are getting a little loose and seem to need constant readjustment.
Has anyone ever installed the power-adjust, heated towing mirrors as a retrofit? Is all of the wiring already in place? Where is the adjustment control located? Hopefully I can get everything I need from a junkyard, I just need to make sure that I get all of the needed parts.
Here is a thread I started that might help answer some of your questions. If you search around you will see several examples of folks who have done it.
https://www.ford-trucks.com/forums/1...ar-models.html
Tow mirrors swap
I have on 01 f250 and I damaged my passenger tow mirror. I found a set from a 2005 f250 with heated glass and turn signal he had adapters in the box with them. While looking at my plugs it looks like it's a flat plug going into a round plug adapter. My question does the round plug adapter be removed from the flat plug and be plugged straight into the new mirror?
