PO475 Trouble Code
06-04-2011, 06:21 PM
on
PO475 Trouble Code
Need some help...
Just installed a new GTP38 Turbo and Non-EBPV pedestal. What do I do with the connector that attached to the EBPV sensor? It keeps spitting out the PO475 toruble code!!!! Driving me nuts!!!
Thanks ahead of time!!!
06-04-2011, 08:57 PM
on
Put a 470 ohm 1/2 watt resistor across the pins in the plug, fold the wires in half and stick in the plug. Resistor can be got at Radio Shack.
06-05-2011, 04:09 PM
on
Thanks!! Just picked 5 of them up for $1.59! Ill install it as soon as the truck cools off enough!!
Thanks again!!!
06-05-2011, 07:44 PM
on
Okee dokee!!! Problem fixed! Thank you very much again!!
06-05-2011, 07:50 PM
on
Cool glade you got it taken care of.
06-05-2011, 07:57 PM
on
Just out of curiosity, with that resistor value, what does the ECM see?
06-05-2011, 08:01 PM
I'm curious too.... does it make the code go away all together?
I know theres a plug you can buy and plug into the harness that is supposed to get rid of the code... but it's like $35 or so.
06-05-2011, 08:04 PM
on
The code is gone on my truck... im just wondering what im telling the ECM and if it can potentially affect fuel efficiency etc...
06-05-2011, 08:07 PM
Quote:
Originally Posted by
DCook909
I'm guessing it is just tellin git that there "is" a connection.
BUT when it tries to turn on the EBPV, what happens then?
06-05-2011, 08:15 PM
on
The resistor is the same thing as the $35.00 plug just not as fancy. All the resistor does is mimic the plug being plugged to the solenoid. And all the solenoid does is open a valve and flood a chamber with oil to push out the rod to close the EBPV. Won't hurt mpgs
06-05-2011, 08:17 PM
on
Sounds good to me! Thanks again!!!!
04-15-2013, 11:19 AM
on
VERY GOOD INFO.... THANKS
hondamxr
10-10-2016 08:26 AM
hondamxr
1999 to 2016 Super Duty
10-09-2016 07:30 AM
JJD
08-01-2016 11:01 AM
ChunderDownUnder
03-26-2011 09:39 PM
60RatRod
16
06-16-2010 01:32 PM
01 ,
2002 ,
2003 ,
73l ,
code ,
codes ,
diesel ,
dtc ,
engine ,
explorer ,
ford ,
jeep ,
obd ,
po475 ,
trouble
