Po475 trouble code
Old Oct 8, 2016 | 02:57 PM
hondamxr's Avatar
hondamxr
Po475 trouble code
I'm trying to get my truck smogged and having problems w/po475. A friend of a friend said it was the DFPE sensor. So I bought one for $120 bucks but can't find where it goes. On YouTube it is only listed for F150's and gas motors it seems. I have a 00 f350SD 7.3, do I even have a DFPE and if so where is it located. Any info would help.
Thanks
Old Oct 8, 2016 | 03:07 PM
coax9952's Avatar
coax9952
Never heard of it, and I would NEVER blow 120$ on the friend of a friend.....what's it supposed to be?
Old Oct 8, 2016 | 03:17 PM
hondamxr's Avatar
hondamxr
Po475
He even had a print out on how to clear the code after it's replaced? I looked it up and it is for po471 code and something like an egr problem. . Do diesels have egr valves?
Old Oct 8, 2016 | 03:23 PM
coax9952's Avatar
coax9952
Nope, not on a Diesel.....What did you use to read your codes? most off-the-shelf scanners don't work on our trucks.
Old Oct 8, 2016 | 04:46 PM
mueckster's Avatar
mueckster
P0475 is also a code for a 7.3 diesel. It refers to a problem with Exhaust Back Pressure Solenoid and/or its wiring.
KB1 DIAGNOSTIC TROUBLE CODE.docx
Old Oct 8, 2016 | 05:52 PM
coax9952's Avatar
coax9952
Yeah, that's what my book says. I was hoping his friend told him what the acronym meant. or at least give him an idea...
Old Oct 10, 2016 | 07:46 AM
Tugly's Avatar
Tugly
You may need to pull the Exhaust Back Pressure Sensor and clean it.
Using a code reader and advice of a friend of a friend on a Jurassic diesel is dubious at best - and very expensive at the worst. You are in the right place now - the "collective" knows how to troubleshoot these rigs down to the individual component.
If you have a smart phone or other portable device, you may want to click on the OBDII tools in in my signature.
Old Oct 10, 2016 | 08:26 AM
mueckster's Avatar
mueckster
If you are getting the P0471 code, I'd start with the EBP Sensor and tube, as Rich mentioned. We need to know what exact codes you are getting to point you in the right directions. Get us more information and report back.
Y2K X
Nov 2, 2018 02:39 PM
modular2v
Feb 12, 2011 10:33 AM
fyrbrd
Jun 11, 2010 07:04 PM
mstan99999
1997 - 2003 F150
Jul 28, 2006 01:33 PM
