EBPV Solenoid
Old Nov 17, 2009 | 03:14 AM
ChunderDownUnder's Avatar
ChunderDownUnder
EBPV Solenoid
Howdy all - how do you remove the EBPV solenoid from the pedestal. Im trying to replace the o-rings. Its quiet tight and I dont want to stuff it up..
Old Nov 17, 2009 | 08:48 AM
DND58's Avatar
DND58
Brian, not sure if this is what you're looking for, but may be helpfull.
04-20-2***OIL LEAK - TURBO PEDESTAL SEAL AT EXHAUST BACK PRESSURE ACTUATOR (EBP) - 7.3L DIESEL
Old Nov 17, 2009 | 09:22 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Good post Dean. I think that is what he was looking for.
Old Nov 17, 2009 | 10:02 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Is it leaking from the EBPV rod?
Old Nov 17, 2009 | 03:04 PM
ChunderDownUnder
Thanks guys, This is the bugger here
http://www.dieselorings.com/template...pvsolinoid.jpg
I have the pedestal out - I have the o-rings - none of em are leaking, just tjought while Im here, why not. The backing plate is done and I have undone the Tork nut on the solenoid. You can wriggle the solenoid and I have try pulling it out but like I said it is rather tight. If it is a drama I will just leave it alone.
Old Sep 11, 2010 | 01:17 PM
IRTOUCHED's Avatar
IRTOUCHED
can anyone tell me where i can get the o-rings for the pack pressure selenoid on the pedestal ford does not carry them they said i would have to buy a new selenoid for 300.00 compared to probably 4-5 bucks for the o-rings
Old Sep 11, 2010 | 05:17 PM
ChunderDownUnder
Try Guzzle's
Replacement O-rings for Ford Diesel Engines
Old Mar 13, 2011 | 07:53 PM
ScaldedDog's Avatar
ScaldedDog
No one ever answered this guy's question, and now I'm having the same problem. The actuator will rotate, but I can't pull it out.
It's not leaking, but the o-rings come with Clay's turbo reinstall kit, so I figured I might as well replace them. As far as I can tell, though, there are *no* directions on the web for doing this.
Do any of you know the secret?
Mark
Old Mar 13, 2011 | 08:02 PM
ScaldedDog's Avatar
ScaldedDog
Never mind. The "secret" turns out to be "wiggle and pull". It doesn't come out slowly, but in a hurry, such that the back of your pulling hand will hit anything in the way. DAMHIK\
Mark
Old Mar 26, 2011 | 09:30 PM
2000ford350's Avatar
2000ford350
get-r-done
you have to remove the turbo first then remove the pedestal it takes bout 2.5 hours or so there is a retainer clip or c clip on back part of actuator housing on the pedestal that holds the plug i call it. once you remove clip use a rubber mallet hit on the end of the rod gently just enough to push that plug out then remove components carefully and replace new seal kit
Old Mar 26, 2011 | 09:31 PM
2000ford350
hope that helps you out
Old Mar 26, 2011 | 09:39 PM
2000ford350
Talking get-r-done
Price: $99.72
Code: 2C3Z9P466AB
Exhaust Back pressure Valve piston rebuild kit
go to riffraff diesel.com
2000ford350
hope this helps you out
IH Addict5088
Apr 9, 2017 10:34 AM
Snowseeker
55
Jun 25, 2016 09:10 PM
snake8myelbo
13
Jan 13, 2016 11:08 AM
robjs111
17
Jan 15, 2009 03:48 PM
bad ass diesel
Jan 30, 2007 06:11 PM
