Miscellaneous
automotive abbreviations FTE Tech Article Page GEM Information Oil Pressure Gauge Conversion 1997 Ranger Instrument Panel Light Bulb Replacement Details About the Ranger Sport Option Installing Explorer Seats, Console and Overhead Console in a 1999 Ranger Replacing the Plenum Ranger & Explorer Fading/Blank Radio Display 1992 Radio Light Replacement Radio Wiring Information Dome or Door Ajar Light Stays On Door Panel Removal 1989 Power Door Lock Wiring Cruise Control Repair 1989 Cruise Control Blend Door Fix Charging A/C on a 1998 Style Ranger Adding Foglights to 1998 Style Ranger Bedliner Installation Installing a Tonneau Cover Fuel Pressure Testing Fuel Sender/Pump Replacement Changing the Fuel Filter on a 1999 Changing the Fuel Filter on a 2002 Door Sticker Decoder Additives FAQ about Gas What Size Tire fit on a Ranger What Size Tire Fit on a BII Programing and Determining if You Have Keyless Entery owners manual download MultiMeter Guide Paint Code Information Truck Specifications Disconnecting the DRL System Part Number for 1998-2003 Tow Hooks How to Replace your Headliner The 3.0 Technical Information Page Shift-on-the-Fly 4WD Switch Motor Rebuild https://www.fcsdchemicalsandlubricants.com/Main/quickref/scucEN.pdf Please email me if you have something to add to this thread. FTE is not responsible for the content of these links. |
fte automotive calculators
FTE now has a automotive calculator page figured this was a good place for the link
CALCULATORS |
4r55e 5r55e Ranger / Explorer Transmission Problems
https://www.ford-trucks.com/article/...dy_Gasket.html |
5r55e / 4r44e Transmission fix discussion
https://www.ford-trucks.com/forums/5...lick-here.html Lift options for Rangers Lift Options for 2001+ Rangers Save Those Auto Hubs--Easy Fix With Pictures https://www.ford-trucks.com/forums/4...-pictures.html Fix Ford Radio Illumination Bulb https://www.ford-trucks.com/forums/s...80&postcount=1 |
Replace window regulators
https://www.ford-trucks.com/forums/8...egulators.html Flush and clean auto tranny https://www.ford-trucks.com/forums/652748-full-tranny-fluid-pump-out.html |
Ranger tranny fluid pump out / change
https://www.ford-trucks.com/forums/6...-pump-out.html Ranger 4x2 Ball joints https://www.ford-trucks.com/forums/6...ll-joints.html |
This applies to a lot of the Ford product line & that danged brake master cyl located cruise control deactivation switch, which is a normally closed switch, can stick open & prevent cruise activation, or jog open circuit & have the cruise drop out while in use.
https://www.ford-trucks.com/forums/1...l#post14203895 |
