Front Spring Wedge
Old Mar 6, 2017 | 12:54 PM
Daggers's Avatar
Daggers
Front Spring Wedge
Hi All,
Just removed my front Axle on my '46 1/2ton PU and found one axle wedge missing the other in a 100 bits. Looked but can't find new so will machine a couple from alloy, can anyone advise on the wedge angle?
Daggers
Old Mar 7, 2017 | 08:05 AM
tacomacream's Avatar
tacomacream
Originally Posted by Daggers
Hi All,
Daggers
I will take a look at the front axle and springs that I have this evening and I'll let you know what I see.
Old Mar 7, 2017 | 07:50 PM
tacomacream
I at first thought that maybe there was a wedge under the spring pack. Now I am not sure what an axle wedge is. And then I couldn't see much since it is snowing again.
Old Mar 7, 2017 | 10:42 PM
willowbilly3's Avatar
willowbilly3
Probably to set the caster. Maybe an alignment shop could help but just guessing and putting them back in without knowing the caster is kind of a blind shot.
Old Mar 7, 2017 | 11:05 PM
tacomacream
I just looked again in my operators manual and there is a castor wedge. It doesn't have much of an angle. I can see a slight angle in the bottom piece in the spring pack that I have pictured. I will measure the difference in front and back and the length.
Old Mar 8, 2017 | 03:59 AM
Daggers's Avatar
Daggers
Thanks for looking.
In the Green Book the castor wedge is shown as:-
01Y-5336 Wedge (front Spring) 42-47 Comm & 122" Truck 40-47.
Many vehicles use them, Land Rovers use a three degree wedge to set castor.
Normally the wedge angle is between one and four degrees.
I tried to purchase the above part number but without success.
Old Mar 8, 2017 | 07:50 AM
tacomacream
Here is some information that I found on the '48-'56 forum here.
https://www.ford-trucks.com/forums/1...-question.html
I don't think it would be a good idea for me to measure my castor wedge while it is on the axle and has a rust film on it when we are talking about a couple of degrees of angle. I would feel more comfortable if it was off and clean. But check this site. The frame, except the f-1 has bumper horns, and front springs are the same as yours on a '48-'52 as far as I know.
Old Mar 8, 2017 | 10:45 AM
Daggers's Avatar
Daggers
Followed the link, looks like the original castor wedge was 2deg.
After reading the posts I ordered a couple of Land Rover wedges which are 3 degrees, it will save me machining time. This should give a little more than standard, and I will see how it drives.
Thanks for the info.
Old Mar 11, 2017 | 06:54 PM
bernette's Avatar
bernette
not sure if this could help! i found these today of my 2 ton.
Dano78
Apr 6, 2022 09:23 AM
mebe2k
30
Dec 22, 2015 01:02 PM
newrider3
Mar 15, 2013 07:42 AM
shadowwalker
Jan 1, 2006 01:58 PM
ba 302
1978 - 1996 Big Bronco
15
Jun 8, 2003 12:34 PM
