- Wheel alignment specification
- fuel injectors not all working
- Power Steering Gear Box/Pitman arm question.
- Differential gear swaping
- Towing
- Update on the Turdster Issue
- Where is the EEC-IV / OBD test connector location???
- tire size
- External fuel pump
- Ugh... Turdster Broke Down Again (this time the Turdster had to be towed)
- 4x4 to 4x2 conversion and lowering
- wiring harness for radio help!!!!!
- Weird Noise
- EGR Questions about Code 31 and 84
- Speedometer Hook Up
- stripped out transfer case bolt
- 1987 Ford Bronco 2, opinions please!!
- Ignition switch?
- C5 tranny
- EEC-IV Code 67 ???
- auto hubs
- Installing 2.8 Engine
- extreme broncoII forum
- 87b2- brakes press & engine speeds ?i
- Something Helpful I'd Like to do to the Turdster as well...
- Stand Alone Engine Computer 87 B2
- Changing Spark Plugs on a 84 B2
- Transmission fluid leaking into cab
- TFI Module - Any improvements?
- just started running rough
