Bronco II Ford Bronco II
Ignition switch?
Old Sep 12, 2003 | 08:41 AM
WeWonIt's Avatar
WeWonIt
Unhappy Ignition switch?
My B2 has been acting up latley and has me stumped. I plan to pull codes this weekend, and I have purchaced a Haynes manual and am awaiting its arrival. But the problem is it is not starting every time and has weak spark when it does not start, and good spark when it does start. Now here is the real head scratcher It will start if I hit the steering wheel, this started a fluke brought on by frusteration of not starting. It will turn over every time but will not get a strong spark unless I hit the steering wheel. is there any thing in the ignition switch that could cause this, if so great, it is a cheap fix if not what else might I look for
Thanks!
TROUBLE
Old Sep 12, 2003 | 08:44 AM
WeWonIt's Avatar
WeWonIt
Ignition switch?
Oh Yeah, the coil has been tested to be good, the distributor cap is new, the plugs are new and the plug wires are less than a year old. The starter was replaced this month, and the key ignition will start the truck with out the key sometimes. If that helps any.
exidor12
Sep 13, 2015 06:34 AM
alans77crew
Dec 14, 2013 06:59 PM
sdg0080
Feb 17, 2010 10:26 PM
amazngrace
Electrical Systems/Wiring
May 21, 2008 09:10 PM
Lance1930
Jul 29, 2004 12:17 AM
