Bronco II Ford Bronco II
stripped out transfer case bolt
Old Sep 13, 2003 | 01:29 AM
jrm87B2's Avatar
jrm87B2
Question stripped out transfer case bolt
My filler bolt on the transfer case is stripped. Any suggestions for getting it out?
Old Sep 13, 2003 | 03:19 PM
WeWonIt's Avatar
WeWonIt
How bad is it? If you can get to it try drilling a hole into the bolt and using an easy out bit. I havent had to mess with my transfer case yet thanks to the previous owner letting the Ford house service it less than 2000 miles ago "thank god" but those bits work on just about any bolt if you can get to them. Let me know, the circumstances. I haven't looked at it but I assume that it is a recessed square drive, I'll go look at it today.
Old Sep 13, 2003 | 05:07 PM
jrm87B2's Avatar
jrm87B2
You're right about the filler bolt for transfer case being a recessed square drive.
There is plenty of room to drill a hole but I'm a little hesitant too. I was reading at nother site that Sears has a socket that should removed stripped bolts..not sure if those will work because of the complete circular head. I'm goign down to give it look.
Any other suggestions????
Old Sep 13, 2003 | 06:06 PM
WeWonIt's Avatar
WeWonIt
Those recessed square drives are trickey, but so am I. Take a chisle that roughly fits diagonally across the inside of the square and hammer it in, the chisle needs to be heavy duty and have a shaft that consist of six flat sides so you can turn it with a wrench. once you have sucessfully hammered it in turn the chisle with a wrench and you should turn the bolt also. An added bonus of this method is that it loosens the bolt when you hammer the chisle in, due to the vibration, and makes the bolt more likley to break loose.
Good luck!
Old Sep 15, 2003 | 05:21 PM
jrm87B2's Avatar
jrm87B2
Some good news and some bad news about my stripped outfiller bolt for the transfer case....
I just went down to this transmission shop to see if I could pay them to remove the stripped out bolt and the owner of the shop said to just leave it alone. He said that bolt anodizes (basically welds itself" to the transfer case and you are not going to get it off. To fill it up he said to add oil through the speedometer hole.
Have other peole had this same experience?
1989bricknose
Oct 13, 2020 08:49 AM
alaskarat
1997 - 2003 F150
Oct 26, 2016 01:53 PM
BORDERBUM
Apr 10, 2016 02:36 PM
Ryan Weaver
Mar 8, 2016 04:06 PM
quisp-n-quake
Mar 24, 2008 04:05 PM
