abs
Old Feb 11, 2011 | 04:27 AM
Rivera1114's Avatar
Rivera1114
abs
my abs pump stays on after i shut my truck off does is there any reason why it stays on and if thers is how could i fix it.
Old Feb 11, 2011 | 06:03 PM
alloro's Avatar
alloro
Are you sure it's the ABS pump and not the air suspension pump?
Old Feb 11, 2011 | 06:49 PM
projectSHO89's Avatar
projectSHO89
If the ABS pump stays on by itself, the controller has shorted internally. Full the 4WABS fuse to disable the pump until you can get it fixed at a dealer or repair shop.
You need to properly identify the vehicle you are asking about.
Old Feb 11, 2011 | 11:01 PM
alloro's Avatar
alloro
What is he supposed to Full it with?
Old Feb 12, 2011 | 06:29 AM
projectSHO89
Lol... I need to proofread. Should be "Pull".
Old Feb 12, 2011 | 06:18 PM
American Air-1's Avatar
American Air-1
Again...are you sure its the ABS? My first thought would be to check the ABS relay. The relay is what gives power to the ABS pump.
Old Feb 13, 2011 | 12:21 AM
Rivera1114's Avatar
Rivera1114
yes its the abs pump i dont have air suspension and its a 2000 expedtion 2wd
Old Feb 13, 2011 | 08:39 AM
projectSHO89
There is no ABS relay. The pump/controller is fed by an ALWAYS HOT feed (BJB F102). If the pump continues to run after the switched ignition feed is removed, the control module has failed.
Boyd'z Toy
Mar 26, 2013 08:18 AM
hatchet
1978 - 1996 Big Bronco
16
Dec 25, 2010 11:47 PM
darkmage55
1997 - 2003 F150
May 18, 2010 03:03 PM
Meterman
1983 - 2012 Ranger & B-Series
Dec 22, 2006 06:58 PM
westladog
Oct 25, 2005 06:47 PM
