waterpump
Old Sep 29, 2010 | 08:28 PM
fishernut's Avatar
fishernut
waterpump
1964 F250 4x4
The water pump has a small hole in the housing under the shaft. What is this hole for? It does not leak, but the one on my '63 Coup DeVille does leak. Is this a bad waterpump or canit be fixed?
THanks
Old Sep 29, 2010 | 08:35 PM
arctic y block's Avatar
arctic y block
The hole is a vent. If coolant comes from it than the waterpump seal is bad and most likely a bearing as well.
Old Sep 29, 2010 | 09:34 PM
Customcab's Avatar
Customcab
To add to Artic's comment; its called a weep hole down our way; as mention if its starting to leak anti-freeze; your pump is going out.
Old Sep 30, 2010 | 11:04 AM
Mike G's Avatar
Mike G
Originally Posted by Customcab
... if its starting to leak anti-freeze...
And/or weep anti-freeze.
Old Sep 30, 2010 | 12:11 PM
SixtySix Ford's Avatar
SixtySix Ford
If the one on your 63 leaks then you need to replace it before to much longer!!! Or you will replacing more then a water pump! When I was a tech at a local ford dealer a lady had her 96 F250 with a 460 towed in because someone told her not to worrie about! So it caused her to run out of antifreeze and it cost her a new engine!
Old Sep 30, 2010 | 02:23 PM
crashtke's Avatar
crashtke
Ouch. It is amazing what some people will tell you about cars. It is pretty out of hand in the import world as well.
mudrat025
Jun 19, 2016 06:32 AM
88rustyred
1978 - 1996 Big Bronco
Aug 19, 2012 09:36 PM
trapperjack
Sep 18, 2009 10:45 PM
98Sporty
Jul 27, 2004 03:07 PM
Bob_Smith
Sep 22, 2003 12:32 AM
