Replacing water pump-351M-1979 Help
Old Sep 18, 2009 | 10:13 PM
trapperjack's Avatar
trapperjack
Been a while since I've worked on one of these. 79 F250 supercab 4x4 automatic used to have a/c, none now, will again.
Anywho , waterpump appeared to be weeping from the weep hole. Yanked it off tonight, bearings seem tight. impeller looks fine. Is there supposed to be a gasket between the backing plate and block? Wondering if the backing plate gasket was leaking, because waterpump feels/sounds/acts fine, now that it's sitting on the tailgate.And the top of the backing plate is loose next to the block (no bolts).
Chilton's and haynes are the usual paperweights they are: almost
remove water pump
installation is the reverse of removal
Any ideas?
Old Sep 18, 2009 | 10:31 PM
ranger429's Avatar
ranger429
If water was coming out of the weep hole that means the seal is shot. Replace it with a new pump or otherwise it will leak again. Yes there is supposed to be a gasket between the plate and block. The guy that worked on it last might of just used silicone.
Old Sep 18, 2009 | 10:45 PM
trapperjack
Thanks for your help, ranger429, yet again. You may just be my favorite yankee.
Skydivelout
Aug 26, 2016 05:30 AM
mudrat025
Jun 19, 2016 06:32 AM
KJNDIVER
61
Jun 2, 2016 08:33 AM
GuitarJesus
Nov 28, 2015 03:14 PM
54Guy
Apr 19, 2009 05:52 PM
