Leaking lots of Coolant from 4.0 SOHC
My check gauge came on as my temp gauge pegged out today. I pulled off the freeway into a gas station after 1/8-1/4 mile. Coolant was leaking rapidly out of my 98 Explorer Sport. A few minutes after it stopped dripping antifreeze, I added about a quart of antifreeze to the radiator. Then looking underneath from the front it seems to be leaking from around the bottom of the waterpump just above the crankshaft. Does this happen often on the 4.0 sohc engine? How difficult is it to replace a waterpump on this engine - assuming that's the problem. Any advice as to what happened? Explorer has 120,000 miles on it. How much does a new waterpump cost? Thanks! This is my first post although I've been visiting for a while.
Impeller came off the Water pump shaft
I've started to pull it apart. The leak was from the weep hole in the water pump. When I pulled off the waterpump, the impeller and a little metal part fell out. The metal part is like a 1/2 inch silver(steel)dia disk,1/16 inch thick, fastened to a 1/4 inch dia bullet shaped body about 1/2 long gold colored(cadmium plating?). The impeller is worn in one spot and the housing is worn in a corresponding circle. I'm taking off the thermostat now to see if that's where the part came from.
ElMoco
46
11-28-2016 09:42 PM
hancockr
10-17-2007 12:42 PM
leeesselman
08-20-2004 09:59 AM
streamin along
03-03-2003 11:49 AM
