IDM Failure code & High Side Open Bank 1&2
Old Sep 24, 2010 | 11:49 PM
cutlass's Avatar
cutlass
Today I just installed a brand new IDM and after running the Injector Buzz Test test, I received codes: P1298 Injector Drive Module Failure, P1293 Injector High Side Open - Bank 1, and P1294 Injector High Side Open - Bank 2. Can anyone help explain how a new IDM could throw these codes?
When running the KOEO test I received codes P0605 Injector Control Module Read Only Memory (ROM) Error, P1298, P1293, & P1294.
My engine is still missing but the engine is running a heck of a lot better after replacing the IDM and injector 8 has a rotational velocity of about 3%
Thanks,
Drake
Old Sep 25, 2010 | 12:18 AM
mueckster's Avatar
mueckster
This schematic may help to explain these codes. Look at the box at the lower left for the codes. Sounds like a wiring problem between the IDM and connector outside the the VC.
Have you cleared the codes and rechecked?
Old Sep 25, 2010 | 12:32 AM
cutlass's Avatar
cutlass
Attachment 28062
Which connector outside the VC are you referring to? The actual under valve cover gasket with harness or the engine wiring harness connector?
Old Sep 25, 2010 | 12:35 AM
cutlass's Avatar
cutlass
Could this possibly have something to do with the IDM Relay(s)?
Old Sep 25, 2010 | 12:47 AM
mueckster's Avatar
mueckster
The 9 pin connector that plugs int the VC on the outside of the gasket. It could also be at the 42 pin connector. These wires go from the IDM connector thru the 42 pin to the 9 pin connector, thru the VC , and on to the UVCH .
The IDM relay provides the power to the IDM and would not affect these codes.
Have you done the cylinder contribution test also?
Old Sep 25, 2010 | 07:02 AM
cutlass's Avatar
cutlass
Yes, and it passed the cylinder contribution test.
Do you have any reason to believe that my new IDM is damaged already by a bad connection?
I also performed the ohm test from the IDM harness connector and everything checked out fine.
Old Sep 25, 2010 | 07:40 AM
mueckster's Avatar
mueckster
Is this a new IDM from Ford? I got some codes like this when dealing with reman units. I still get a P1298 code IDM failure, but all my wiring ck'd out ok and ran fine. Did you wiggle the wires while testing to ck for intermittent opens?
NA20 DIAGNOSTIC TROUBLE CODES (DTCs) P1294 AND P1293: CHECK FOR VOLTAGE ON HIGH SIDE CIRCUIT
DTCs P1294 and P1293 indicate an open circuit exists on the high side circuit between the IDM and the injectors. The following table lists the circuits to inspect while performing these pinpoint tests, based on the DTC retrieved during the KOEO On-Demand and Injector Electrical Self Tests.
DTC High Side Injector Bank
P1294 878 (PK/YE) Left
P1293 1087 (OG) Right
Key off.
Disconnect the connector on the bank with the code.
Key on, engine off.
Measure voltage on the suspect high side circuit Pin E on the injector vehicle harness connectors and battery ground.
Is voltage greater than 1 volt?
Yes No
GO to NA21 . GO to NA24 .
Old Sep 25, 2010 | 08:22 AM
cutlass's Avatar
cutlass
Key off.
Key on, engine off.
Yes No
I'm not sure if the IDM is new or re-manufactured. I got it from Clay at RiffRaff. If I were to guess, I would say it was re-manufactured, but I'm not sure.
When I have time, I will have to perform the tests you suggested here and let you know what I get.
Old Sep 25, 2010 | 08:49 AM
mueckster's Avatar
mueckster
PM sent. I can send the test procedures.
Old Sep 25, 2010 | 09:44 PM
mueckster's Avatar
mueckster
Email on its way. Start with NA20 DIAGNOSTIC TROUBLE CODES (DTCs) P1294 AND P1293: CHECK FOR VOLTAGE ON HIGH SIDE CIRCUIT
and go from there. Good luck!
Old Jan 7, 2017 | 03:24 PM
Jayson Zokan's Avatar
Jayson Zokan
7.3 injector
Afyer noon ! Do you still have the test procedure for the 7.3 I have above 1 volt and you said go to NA**
Old Mar 4, 2022 | 01:30 PM
Dstone70's Avatar
Dstone70
Procedure for 1293,1294
I could use the procedure myself
Old Nov 1, 2023 | 05:37 PM
Mhawk's Avatar
Mhawk
3rd Gear
P1293 and p1294
Can someone send me this procedure as well
Old Mar 11, 2024 | 11:59 AM
Big Bo's Avatar
Big Bo
4th Gear
Need test procedures for P1292 high side left shorted to ground or B+
I have done everything I know what to do and I’ve come up with this code my 7.3 still runs like crap and I’ve had it in every shop that’s around here and nobody can figure it out I need help
Shattered
82
Feb 11, 2018 07:51 PM
SNOWR8R
Oct 6, 2017 12:12 AM
unluckyjack
General Diesel Discussion
Apr 29, 2017 01:28 PM
DRRXR
Oct 30, 2016 01:22 PM
fordpride
15
May 23, 2016 01:00 PM
