DP or MBRP
Old Sep 18, 2010 | 06:06 PM
  #31
jhand124's Avatar
jhand124
Originally Posted by jcobb124
What about the sound? Loud? Whistle? I am very indecisive!
Not much different, but it sounds cool when you open the pass window and have a wall or something next to you to bounce sound off of.
Originally Posted by Joe28443
So higher RPM equals lower EGT? I am curious if I need to leave it in stock until I get gauges. I have only towed it a few times and it seemed to tow in OD with the RPM's around 1800-2000. Should I tow with the OD off with out the 60T or with it? How do you guys tow?
Just don't lug it up a hill, this can happen in 3rd at 40 mph too, I have had to down shift to 2nd before. Gauges first.
Originally Posted by aklim
Gauges before all other stuff. That way you can see what the effect of each item you add on is.
Ditto
Old Sep 18, 2010 | 09:26 PM
  #32
jcobb124's Avatar
jcobb124
Yes a WW is definitely next on my list!
Old Sep 19, 2010 | 07:53 AM
  #33
aklim's Avatar
aklim
Are you having surge? If not why use that? IF so, maybe the ported housing might be more money out the door but might pay off in the long run for surge control. IIRC, the WW does move less air.
Old Sep 19, 2010 | 07:56 AM
  #34
jcobb124's Avatar
jcobb124
I am not having surge issues, I just want to make her whistle!!
Old Sep 19, 2010 | 09:45 AM
  #35
aklim's Avatar
aklim
But if it moves less air, you might lose some power.
Old Sep 19, 2010 | 02:11 PM
  #36
Bonanza35's Avatar
Bonanza35
Jhand124, if you have no cat and the walker mufferthis will serve you well. John Woods put this on his dyno and said it is the same as 4" exhaust with just a chiped truck,"but" you can be towing up a hill and not even know it at low rpm's and the EGT will raise real quick. Gauges for this is a must! If your trailer is super light probably not an issue, but travel trailer or toyhauler be really careful. Your pcm will probably defuel and blow black smoke but you don't want this to happen more then once, that is even lucky. Blow the money on safty asap it could save your motor and real procket bock. Chet
Old Sep 19, 2010 | 10:22 PM
  #37
aklim's Avatar
aklim
I think while that is an issue, having gauges is nice for diagnostics in some circumcisions.
Old Sep 19, 2010 | 11:22 PM
  #38
jhand124's Avatar
jhand124
I think you meant this for the OP.
Old Sep 20, 2010 | 03:44 PM
  #39
sp33dracerman's Avatar
sp33dracerman
Alright guys I need some input!!
I am fixing order one of the following items DP Tuner or MBRP exhaust systems 4" TB. My current mods are 6637, Walker Muffler, SuperChips Programmer. So what would you guys do?
I love my dp tuner but I already have an exhaust so you may want to get that first
Old Sep 22, 2010 | 02:02 PM
  #40
Spool&Go's Avatar
Spool&Go
Glad you got the exhaust first. I did the same. About to buy the DP. I was always told. Make sure you have sufficient air in and out before you throw any kind of chip or tuner on. And I really do agree.
Old Sep 22, 2010 | 10:30 PM
  #41
jcobb124's Avatar
jcobb124
Ok... So I got my MRBP kit in today from RiffRaff, has anyone installed one these kits before? Any tips and or suggestions??
I am going for it this weekend! I can't wait I am stoked!!
Old Sep 22, 2010 | 10:44 PM
  #42
KH85's Avatar
KH85
I have always thought this was a great idea on any rig!
OP: Good call on the exaust!
slowmans
6.4L Power Stroke Diesel
Oct 28, 2012 09:33 PM
savage250
Jan 5, 2011 06:30 PM
strokin71
Feb 5, 2009 05:10 PM
PETE'S_6.0PSD
Nov 13, 2008 01:18 PM
wfmcbride
Jan 6, 2007 08:46 PM
