MBRP Turbo Back Kit "Down Pipe" Size
Old Jan 6, 2007 | 03:20 PM
wfmcbride's Avatar
wfmcbride
Question MBRP Turbo Back Kit "Down Pipe" Size
Hi Guys,
I'm getting ready to go 4" straight piped with the MBRP 409SS kit.
It seems this kit comes with a 4" Down Pipe and I've read that a stock 7.3 non-chipped engine should stay below 4 inches on the DP.
Any knowledge on this subject would be appreciated, maybe the design of this system requires it?
Thanks in advance, Walt
Old Jan 6, 2007 | 03:26 PM
hosemandc's Avatar
hosemandc
I have never seen anyone use anything larger than a 4 inch down pipe. After that the rest of the exhaust system can go up. After installing my 4inch down pipe last night I wouldnt imagine any thing larger would fit. I know some people are installing a 3.5 inch but I figure if you are replacing stock you might as well go for the 4.
Old Jan 6, 2007 | 03:52 PM
wfmcbride's Avatar
wfmcbride
Hi Hosemandc,
My question dealt with staying less than a 4" DP on a stock engine, like stay with the stock 3" DP or go up to a 3.5" IF that is possible with MBRP kit.
Old Jan 6, 2007 | 03:56 PM
GREGROB's Avatar
GREGROB
The downpipe that most closely matches the outlet of the exhaust housing is best. On a stock turbo, that would 3.5".
If you can get the kit with a 3.5" DP, go for it. Otherwise don't worry about it. It's NOT that big of a difference.
An aftermarket DP will flow much better than the disfigured stocker regardless of size.
If you plan on mods that will increase egt's, at least go with a 3.5" aftermarket DP.
Old Jan 6, 2007 | 05:23 PM
ponch37300's Avatar
ponch37300
I have read that the 4" doesn't have the back pressure needed without all the mods and it is to free flowing on a stock truck. I believe it created a little turbo lag on the low end if i remember reading correctly. I have the mbrp turbo back with 4" dp and 5" exhaust and i didn't notice any negative effects.
Old Jan 6, 2007 | 05:32 PM
GREGROB's Avatar
GREGROB
Backpressure = bad. Your truck does NOT need back pressure.
What the 4" dp does do is move the powerband up a little more.
The reduced back pressure from a free-flowing exhaust will help the turbo spool up better.
Old Jan 6, 2007 | 06:17 PM
Muktown's Avatar
Muktown
i would go with a 4 inch down pipe. if you do any mods or tow you will have reduced egts with a 4 inch over a 3.5 also i recommend getting the muffler delete pipe with your kit. it sounds awesome
Old Jan 6, 2007 | 06:33 PM
Uzumati's Avatar
Uzumati
What's this muffler thing people keep talking about?
4" = Good and it will support anything you may want to do in the future
Old Jan 6, 2007 | 06:37 PM
GREGROB's Avatar
GREGROB
I heard of one once, apparently some sort of device that restricts the exhaust and makes it quiter.
Why would you want do that?
Old Jan 6, 2007 | 08:46 PM
wfmcbride's Avatar
wfmcbride
Hey Thanks Guys,
I know a little bit more now, I tow a 30ft goose about 6k dry wt. I haven't had problem one pulling hills up to the mountains, I've just been trying to improve any design flaws like air intake and exhaust.
Thanks to FTE, I do all my own maintenance and have fixed a lot of stuff, VSS sensor, over head computer, door ajar light, etc.
Only problem is time sharing on the computer with the little women, she only works 3 days a week
Walt
slowmans
Ford Truck Parts for Sale
Nov 30, 2013 10:29 AM
Crewcab Turbo
May 15, 2013 05:42 PM
bubba_3711
Mar 8, 2012 10:10 AM
JesseRohr
2004 - 2008 F150
21
Mar 20, 2008 11:24 PM
XxfirmanxX
Dec 27, 2005 09:27 PM
