'97 460 ignition problems
Old Apr 16, 2018 | 08:37 PM
Bigcountry93's Avatar
Bigcountry93
Did you Never figure the problem out?
Originally Posted by IMPRTKLLRZ28
that kind of sounds like the issues my truck was having.....Intermittent no start or would die.....Only happened when it was like over 80.....I would leave work go through like for signal lights, then hop onto the freeway and it would die. It just crank/but no start, get the truck towed get it home start it up the next day and it ran good for like 5 mins and then shut down. Replace my distributor with a genuine ford unit runs great now.But that was my experience.
having the same exact problem with my F350
Old Apr 17, 2018 | 05:28 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
https://www.ford-trucks.com/forums/1...50-issues.html
Hi, I'm just bumping you up to the top and wishing you luck. It's best to start with more information about your truck, test voltage and charging, pull codes and test fuel pressure. But I will venture a WAG and say it is probably the PIP in your distributor. If you want to search for more info, use the name subford in your search. He has helped several people through similar problems lately and has good technique for isolating the problem, separating ignition problems from system problems. Several people, while chasing similar problems, have replaced the whole ignition system(PIP, ICM, coil, cap, rotor, wires). Don't go to the nearest chain store and buy cheap crap made in china. For example some "rebuilt" distributors come with recycled PIPs. So you buy a cheap distributor and then have to go back and replace the PIP again.
Old Apr 17, 2018 | 06:07 AM
subford's Avatar
subford
2X ^^^
Note that this Thread is eight years old.
You need to start a new Thread for your problem.
But yes it sounds like a bad PIP sensor.
Old Apr 17, 2018 | 09:09 AM
Bigcountry93
copy that. Thanks for the info.
giles45shop
37
Sep 3, 2020 04:47 PM
91 7three
Sep 29, 2015 05:35 PM
f150xltlarait
Apr 22, 2014 10:17 AM
gregpatey
2004 - 2008 F150
Oct 29, 2013 07:10 PM
jhoobs
1983 - 2012 Ranger & B-Series
20
Dec 12, 2003 11:44 PM
