Wiper Problems
Old Sep 18, 2003 | 10:11 AM
jhoobs's Avatar
jhoobs
Wiper Problems
On my 97 Mazda B4000, my windshield wipers are acting up. In the first position and accessory position on the ignition switch they fuction properly. However when I start the engine, the wipers will cycle once and then quit working. I checked the fuses they are ok. Does this sound like a bad relay switch??
Thanks
jhoobs
Old Sep 18, 2003 | 10:19 AM
trojanman25's Avatar
trojanman25
Wiper Problems
i have the same problem, unless they are turned to constant, they dont work well, sticking halfway and stuff.
i heard of a wiper delay behind the radio, but i dont know what to do when i find it
Old Sep 18, 2003 | 07:09 PM
Ken00's Avatar
Ken00
Wiper Problems
I would check the multifunction switch and the connector, common failure point.
Old Sep 18, 2003 | 09:21 PM
Rockledge's Avatar
Rockledge
Wiper Problems
On my '98, the wiper delay function is performed by both the Multifuntion Switch and the Generic Electronic Module (located behind the radio) working together. The GEM provides a speed-dependent interval wiper feature. During the INT mode, the delay between wipes will decrease with higher vehicle speed to compensate for increased water on the windshield.
Old Sep 19, 2003 | 12:21 PM
ivanpros's Avatar
ivanpros
Wiper Problems
99 ford ranger 3.0
I have the same problem. Phantom wipers. Mechanic told me I have to change the multi-function switch. any further information would be helpful.
Old Sep 19, 2003 | 04:18 PM
jhoobs's Avatar
jhoobs
Wiper Problems
I will check the connector to the multifuction switch hopefully this weekend.
Thanks
Old Sep 19, 2003 | 08:27 PM
Ken00's Avatar
Ken00
Wiper Problems
I would have to agree with your mechanic.
Old Oct 10, 2003 | 09:57 AM
jhoobs's Avatar
jhoobs
Ken,
Old Oct 10, 2003 | 10:04 AM
jhoobs's Avatar
jhoobs
Ken, I started getting into replacing the multi-function switch and have a few questions. I pulled the radio, but there are 3 to 4 modules behind the radio. Which one is the multi-funtion switch? on the left? Also I went to the Local Ford Dealer to inquire about the switch. The parts guy said that Mazda may be using a different multi-function switch than used in the Ranger. Can you verify if they are the same or not? One further question, the cost. Ford parts guy said $181.00. Can you get this cheaper from an aftermarket such as Auto Zone or NAPA?? Thanks for any help in this.
Jhoobs
Old Oct 10, 2003 | 05:10 PM
Ken00's Avatar
Ken00
The multifunction switch is on the steering column, the turn signal stalk. Do you mean the GEM module?
Old Oct 10, 2003 | 06:22 PM
99 ranger bob's Avatar
99 ranger bob
didnt they have a recall on this a while back i know my 99 went in for a replacement part for something with the wipers when it was almost new
Old Oct 10, 2003 | 06:57 PM
jhoobs's Avatar
jhoobs
Ken, I think you are right, it must be the GEM module. I went and replaced the turn signal/ wiper stalk (multi-function switch) this morning. It still did the same thing even with the new one. So if I replace the GEM module, that should cure it? Do you have a part number for the GEM module on the Mazda?
Thanks
Jim
Old Oct 10, 2003 | 07:23 PM
Ken00's Avatar
Ken00
You will need to upload the data from the old one and download it into the new one with a scanner.
Old Oct 11, 2003 | 06:42 PM
jhoobs's Avatar
jhoobs
I need to upload the data from the old multi-function switch into the new Multi-function switch?? or are you talking about the GEM module?? Please clarify
Thanks
Old Oct 11, 2003 | 06:55 PM
Ken00's Avatar
Ken00
The GEM.
