TSB 09-8-03
Old Aug 18, 2010 | 06:53 PM
Striderwv's Avatar
Striderwv
TSB 09-8-03
Some of you may recall my eot has been running 30 degrees above my ect. Took the truck into the dealership for a scan. Specifics of scan: customer states that the oil temp is 30 deg. higher than coolant temp. ran ids tester koeo-pass koer pass cont dtc-no codes. monitor ect-181 + eot-192. edge monitor readings-ect 176 eot 182. visual npf. hot line assistance request going off of what customer states, would have to do TSB 09-8-03. possible egr cooler, oil cooler, thermostat, head or head gasket. Its my understanding this TSB is basically exploratory surgery.
Given I only have the temperature differences and very small white stains at the degas bottle (everything else seems fine), I have been leaning toward the oil and egr coolers and not the thermostat, head or head gasket. However, I would appreciate your all's feelings. Thanks.
Old Aug 18, 2010 | 06:58 PM
bismic's Avatar
bismic
Send me a PM w/ an email address if you want a copy of the TSB.
jfletcher72
Aug 2, 2013 10:35 PM
bcollison98
Jul 25, 2013 09:31 PM
ruffneck30
Jan 25, 2012 08:05 PM
SoCalSuperDuty03
Jan 8, 2012 02:19 PM
hndacr
Jun 2, 2010 08:31 AM
