What did you do to the X today?
Old Jul 16, 2011 | 03:34 AM
  #811
SkySkiJason's Avatar
SkySkiJason
Originally Posted by robert_l_ross
What will you use as an inverter?
Do you still have the stock stereo? If not, do you have a double-din replacement? I will be adding USB ports/Aux. In port in the "pocket" of the Metra mount unless I find a good double-din replacement.
I have a 1200watt inverter I plan to mount somewhere in truck and have outlets scattered around where I think I may need them (each row of seats and a couple in the cargo area?) I also considered just gutting one of the cheeep 100watt cig lighter inverters and putting the 'guts' behind F650 dash...
I have a double-din DVD/Nav system in the F350 and will do the same for the X eventually. My next system will have USB input(s), so thats why originally wanted USB's on dash - but it seems like all these new phones have USB-based chargers and rather than use an 'adapter' to charge phone, I figured just put a USB in the dash somewhere...
Old Jul 16, 2011 | 05:07 AM
  #812
jd58980's Avatar
jd58980
Loaded the Bronco on the car trailer being towed by the EX. Going for a trail ride in Richloam, Florida. Should be a good time, going to be HOT but fun....
Old Jul 16, 2011 | 07:54 PM
  #813
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
I replaced the rear hatch lock actuator....with thanks to Servinghim!
https://www.ford-trucks.com/forums/1...l#post10582721
Old Jul 17, 2011 | 07:53 PM
  #814
beefcake's Avatar
beefcake
synthetic oil in, factory tech valve body in, synthetic trans fluid and new filter,
home made napa filter kit, diamond eye no muffler 4" turbo back exhaust
new rear shocks, weather tech window deflectors
Old Jul 17, 2011 | 07:56 PM
  #815
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
given mine a break for the last few days, since my grandpa is out of town and left his f-150 with a full tank of gas(not full anymore!) and tossed the keys to me...gotta love free gas!
Old Jul 17, 2011 | 07:57 PM
  #816
locknload223's Avatar
locknload223
Installed V-codes, F350 blocks, and adjustable track arm. Also greased my steering.
Old Jul 17, 2011 | 08:00 PM
  #817
sddesigns's Avatar
sddesigns
FTE Emeritus
Maybe this Fall at Brownies we can do mine too!
V/B's that is!
Old Jul 17, 2011 | 11:29 PM
  #818
phoneprincess's Avatar
phoneprincess
I put new headlights in mine today. Well I didnt but I watched my uncle ron do it. I had the wrong headlights in there (no I didnt put them in). Now I will be able to see at night!!!
Old Jul 18, 2011 | 04:53 AM
  #819
locknload223
V/B's that is!
Not that bad of a job at all. Mine took a little longer because I had to retrofit my airbags to the new blocks. I'll give ya a hand if I make it up. Is there a date yet?
Old Jul 18, 2011 | 04:56 AM
  #820
sddesigns's Avatar
sddesigns
FTE Emeritus
No date yet, it was just talk in the thread after Spring fling was over.
Old Jul 18, 2011 | 03:45 PM
  #821
Elmo154's Avatar
Elmo154
Rear Passenger Window Switch
Replaced the dead rear passenger window switch with one that works.
Old Jul 18, 2011 | 04:52 PM
  #822
robert_l_ross's Avatar
robert_l_ross
I did the "tinfoil fix" to the rear hatch actuator today. Did it from memory so I ended up drilling all of the rivets out (metal and plastic). I found a single layer of foil kept tearing, so I put a good three or four layers on the resistor plate.
I ended up using some tiny bolts and nuts on the middle three plastic rivets to put the unit it back together, and to help support the side with the two metal rivets, I just used a heavier zip tie.
Testing the lock/unlock while watching shows no signs of the actuator case flexing or trying to come apart, so I think it should be just fine with the zip tie/bolts holding it together.
Kudo's to whoever discovered that little fix! Took about 20 minutes to do.
Old Jul 18, 2011 | 06:10 PM
  #823
Snowseeker's Avatar
Snowseeker
I guess that is better then replacing it with another one that doesn't work.
Old Jul 18, 2011 | 06:56 PM
  #824
Elmo154's Avatar
Elmo154
Fickle Windows
Or one that only works on Tuesday and Thursday like the side vent windows.
Old Jul 18, 2011 | 07:15 PM
  #825
alien4fish's Avatar
alien4fish
New PCV valve, new air filter, and a good washing and drying
