What did you do to the X today?
#2311
#2312
Never read any of that information... You mean I could have been doing this all wrong? I have paused like 4 times already with just drawing a line after the last number. Also never heard anything about a $&#*#^%@ reset...
[EDIT]You can actually see my marks in the picture... DOH!!![/EDIT]
Plus it has the location of where the codes can be in the truck if you feel like bending yourself into a pretzel to see them...
#2314
#2316
#2317
Nothing comes up with Nite Ize at Harbor Frieght, got more information on that?
I see it's only available in store for $10. I got mine as an open box return for $7 and you can always find a 20% coupon for Harbor Freight.
#2318
If anyone needs dash mounts (for phones, iPod, gps, etc.), be sure to check out a mount called "Kuda". I use one for my GPS and I think it's pretty nice...covered in "leather", fits tight to the dash and it's pretty solid. For our trucks they make an upper dash model (above the stereo), lower dash (look at the pocket by the adjustable pedal button).
#2319
Received 5,160 Likes
on
#2322
ssdesigns, that was not the point of failure, it was the adhesive on the backside of it. The velcro stuck together very well and is very hard to separate. I even made sure that I cleaned the plastic off of the pillar since it had been cleaned and finished with Armour All before not making a very good surface to try and stick anything to.
On the other hand, as a word of caution, the adhesive on the dash velcro holding my Scangauge on in the '02 started giving way last fall. I have it mounted right below the headlight switch. When I took the old velcro off, I used the 3M adhesive remover in the spray can to clean off the residue. On one side, it started to actually like melt the plastic and began to take some of the color off. It's not real noticeable right now (with the SG & velcro off that is), but it really surprised me. Granted that plastic part is much darker in the '02 than the '05, so maybe it was just removing years of grime? I don't think so though.
#2323
#2325
If you haven't already done so, we can knock out the 50cent mod and whatever other projects you have on your list...
