What did you do to the X today?
Old 05-19-2023, 08:35 AM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Received 4,814 Likes on 2,675 Posts
Originally Posted by jasonodsky
Replaced the shift tube bushings on the top of the steering column. Now the shifter feels as good as new. No more sloppyness.
The old bushings were toast. Installed the new ones with a little lithium white grease to keep them from drying out like the first ones.
Easy job, 20 minutes taking my time.
Cheers,
Jasonodsky
There was a post a while back (in this forum I believe) with all of the steering column parts that most of our Excursions will need to replace. Do you recall it?
  #53357
Old 05-19-2023, 08:59 AM
rsqfxr's Avatar
rsqfxr
rsqfxr is offline
The following users liked this post:
  #53358
Old 05-19-2023, 09:23 PM
John in OkieLand's Avatar
John in OkieLand
John in OkieLand is online now
installed a fuel sump and felt very lucky to find the prior owner(s) have already installed a Fuel Filter in front of the fuel pump
  #53359
Old 05-20-2023, 03:31 PM
Cliffordbigredford's Avatar
Cliffordbigredford
Cliffordbigredford is offline
I pulled out a small tree and chain link fence that went around the side of my shop.
The following 2 users liked this post by Cliffordbigredford:
  #53360
Old 05-20-2023, 06:29 PM
Rainmaker1's Avatar
Rainmaker1
Rainmaker1 is online now
Originally Posted by Antonm23
Edge makes a dash mount specific for the trucks/ Excursions of these years. Cleans up the look of the install IMHO.
Has anyone ever installed an EDGE monitor above the windshield rear-view mirror?
I would think that would be an ideal location.
  #53361
Old 05-21-2023, 07:17 AM
MobyDick!'s Avatar
MobyDick!
MobyDick! is offline
Red Head
Installed a Red Head steering geer box. Getting the pitman arm off the old box was fun. Took about 6 hours. I may need an alignment now. My steering wheel isn't centered. Perhaps it was hiding in the slop. Had a "helper".
The following 5 users liked this post by MobyDick!:
  #53362
Old 05-21-2023, 08:20 AM
Cliffordbigredford
Sure makes a difference. I just installed a ported blue top last month. The helpers always a benefit.
  #53363
Old 05-21-2023, 09:41 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
ASFC27FTFBQ is offline
Let us know if the slop totally goes away.
  #53364
Old 05-21-2023, 09:56 AM
Cliffordbigredford
I'm pretty happy with how mine feels. I have yet to install the hydro-ram.
  #53365
Old 05-21-2023, 12:47 PM
1css's Avatar
1css
1css is offline
She’s patting the truck. She knows a good truck when she sees one.
The following 2 users liked this post by 1css:
  #53366
Old 05-21-2023, 02:30 PM
MobyDick!'s Avatar
MobyDick!
Drove it today. Slop is completely gone. So much control. No binding with slow parking turns at all. Also (some may not agree due to stability issues being a potential) I disconnected both the front and rear sway bars. I have a helwig in the rear. Used to be jarring over every bump in the road. No longer. And it still drives straight down the road no wander. I do need an alignment due to the steering not being center. Assume it was hiding in the slop. Worth every penny! 6 hour job. Now it's time to fix the missing cat some meth head stole.
  #53367
Old 05-21-2023, 03:35 PM
Cliffordbigredford
I agree with the ride quality and no sway bars. I have the pro comp 22210 fronts and removed a leaf so it has a bit of body roll, but still nice to drive. The sway bar links just get destroyed off road. Better than my friends (According to him) stock 03 excursion.
  #53368
Old 05-21-2023, 03:43 PM
MobyDick!'s Avatar
MobyDick!
I have the pro comp rear springs and bds up front. Upgraded the rear from a block setup. I just disconnected the sway bars. I might completely remove them after some time.
  #53369
Old 05-21-2023, 03:54 PM
Cliffordbigredford
I would like to do that to the rear as well. Do you run a shackled traction bar? That's what I'm waiting for before I remove the block.
  #53370
Old 05-21-2023, 04:02 PM
MobyDick!'s Avatar
MobyDick!
No traction bar. I was aiming for the pirate setup. Shimed the rear and have the springs and shims for up front but haven't installed them. I think the bds springs are just fine. Getting an alignment tomorrow to get numbers to determine if I need shims up front.
Quick Reply: What did you do to the X today?
