Air conditioning -HELP
Old 07-23-2010, 12:08 PM
katbird704's Avatar
katbird704
katbird704 is offline
1996 F-250.. Truck had been down for months. I replaced IDM and is now running. Now my air conditioning is not working. Blowing warm air. It sounds like it's switching over. And when I cut the motor there is water running out under the truck like it would if it working. It was working great last summer. It's 95 here, I need air...
Old 07-23-2010, 12:27 PM
farmert's Avatar
farmert
farmert is online now
Is the compressor clutch engauged when the ac is running? The system may need recharging, but with water dripping under the truck is sounds like it is trying to work. Check the blend door in the heater box, it may be stuck.
Old 07-23-2010, 01:03 PM
chicagodragon's Avatar
chicagodragon
chicagodragon is offline
take a look under the hood. this vac line breaks all the time and allows hot air from outside in.
Old 07-23-2010, 02:49 PM
Moby Dick's Avatar
Moby Dick
Moby Dick is offline
I have an F250 Supercab, longbed and I've been having problems with my air too. Blows cold and then warm. I looked under the hood and sure enough that vac line is broken. Can I replace that with any old rubber vac line or is that something special from Ford?
Old 07-23-2010, 04:26 PM
chicagodragon
any type of hose that fits over it tightly will work
Old 07-23-2010, 09:59 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
That same thing happened to me also. But, mine would blow air out of the defrost vents.
Old 07-24-2010, 01:07 PM
katbird704's Avatar
katbird704
OK, I have my fingers crossed. 2 can of the freon and it's cold. Hopefully no leaks. Where did it go? Glad to have air again..
Old 07-24-2010, 01:09 PM
chicagodragon
look around all the fittings, if you see what looks like an oil leak...thats it
Old 07-24-2010, 01:43 PM
fordpride's Avatar
fordpride
fordpride is offline
An AC system does not use up freon so if you had to add it has a keak somewhere
Old 07-24-2010, 02:23 PM
Action4478's Avatar
Action4478
Action4478 is offline
Hopefully 2 isn't too much .. Most older air conditioning systems leak a little , & the lower the pressure sometimes the more they leak due to the type of fittings . Did the freon can have a gauge on it ?
Old 07-24-2010, 02:38 PM
katbird704's Avatar
katbird704
Yes, it did have the gauge on it.. One didn't bring it up enough. The compressor would kick on and off. The pressure is between 45 and 50.. I checked couple hours after filling seems to be the same.
268Fords
21
08-03-2016 01:18 PM
Riceburnerfb1
21
06-28-2016 04:45 PM
64jmb
06-28-2016 02:27 PM
mytoolman
Aftermarket Products
04-06-2016 12:49 AM
acf6
6.7L Power Stroke Diesel
11-07-2011 05:36 AM
Quick Reply: Air conditioning -HELP
