mpg
Old Jul 6, 2010 | 03:36 PM
David85's Avatar
David85
Originally Posted by Coalroller
also there will be no shifting to 4x4 on the fly (ie. going say 25mph down the road) youll tear your tc apart when the gears take up IIRC im sure someone will correct me if im wrong
Do it all the time in my sister's ranger. Not sure if your truck runs the same setup though.
The ranger is all mechanical, so as long as your hubs are in the locked position, the engagement is undetectable.
Dad's gmc used to have that silly shift on the fly setup that uses a side axle disconnect via some unreliable thermal expander. I since bypassed that disconnect because it kept failing and aren't cheap to replace. Now the front axles are always connected and he can shift on the fly when ever he likes (no more delay either).
Shifting between high and low range is something that can't be done at speed though.
EDIT: total crap I just put here since it assumes matching axle ratios for front and rear ends
Old Jul 6, 2010 | 04:32 PM
Coalroller's Avatar
Coalroller
if the gears are the same in the front as they are in the rear then you can shift on the fly but if they are different front to rear wont that screw with the tc?
Old Jul 6, 2010 | 08:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If you have 4.10 gears in the front axle and 3.55 in the rear, you would never get it in gear while rolling.
And you would also most likely be replacing lots of U joints and drive shafts when you drove in 4x4.
Front tires rotate 70 miles every hour at 2200 RPM with 4.10 gears in overdrive.
Rear tires rotate 80 miles every hour at 2200 RPM with 3.55 gears in overdrive.
I agree running 70 MPH at 2200 RPM should have done better than 11.7 MPG.
Just averaged 18 MPG with my Stroke from here to KC and back, 4.10 gears and an E4OD running the speed limit all the way.
Most of it 65 MPH, but a good bit of 70 MPH.
Old Jul 6, 2010 | 09:45 PM
powerstroker100's Avatar
powerstroker100
Originally Posted by FORDF250HDXLT
you can't compare wrecks to yours.
he's 2wd and SRW.
he can head to the local salvage yard,grab a $150-$200 rear axle w/3:55's,buy some new U-bolts and be done in an afternoon for well under $250 easy.
heck,save even more than salvage yard prices,and get a srw 3.55's from private party.(though the 30 day warranty is nice.)
your DRW rear is roughly $350-$900 (depending on the yard) and then you'd need to pay for gears and installation in the front axle.-likely just be the same,possibly cheaper to have both axle gears swapped....roughly around a grand.
what i would do,is to try and find someone to swap rear axles....'92-97 DRW 3.55 cab and chassis only!! no other year due to vss,and not pickup drw cus it wont fit...you did verify its a C&C right?
thats "kinda" a small window to find lol,to top it off,you need to find a guy with same thing,who is looking for 4.10's who now has 3.55's....i kinda wounder if ford even bothered putting 3.55's in the C&C DRW trucks anyway.
long story short,your stuck paying for gear installation front and rear lol.
well if I had a million dollars maybe I would go through this, but looks like I'm gonna suck it up with the 4:10, people sure did hate me today when I was doing 60mph on the 2 lane nys thruway LOL
Old Jul 6, 2010 | 09:54 PM
nwebbe1079's Avatar
nwebbe1079
Im sure you got alot of dirty look and random fingers... im from upstate, but I know how ornery those city folk (close enough to the city anyway) get
Old Jul 6, 2010 | 10:04 PM
David85's Avatar
David85
Oh boy, major brain fart. Didn't realize it was in the context of running different gear ratios for front or rear.
You're right, I'm wrong.
Old Jul 6, 2010 | 10:55 PM
powerstroker100
OOOH yes you are dead on my friend, while living in NY I have lived in Syracuse, Rochester and New York City, I like Syracuse out of all, I'm in Rochester now don't care for it, once I'm out of highschool and have my welding cards I'm long gone lol anywhere I can start an apprenticeship
Old Jul 6, 2010 | 11:09 PM
nwebbe1079's Avatar
nwebbe1079
ever heard of sullivan county? bout exit 99 on route 17?
Old Jul 7, 2010 | 07:37 PM
Coalroller's Avatar
Coalroller
thats quite alright lol i have them all the time
Willie928
17
Oct 5, 2012 10:06 PM
fordxl68
2004 - 2008 F150
16
Aug 9, 2008 08:49 AM
ernesteugene
21
Jun 9, 2008 07:42 PM
Krochus
General Automotive Discussion
36
Dec 2, 2006 09:13 AM
Paso1
Aug 29, 2004 10:33 AM
