I had a new 1996 5.0, auto, limited slip, short bed with 31" tires. great truck! The best I ever got with it that I checked was 16-17 and that was on a trip to FLA. Running around I got like 14-15 mpg. Most all mp EFI 90's v8's that I've seen and driven are in that range. I'd expect 14-15 avg depending on your area.
Forgot to mention how to improve the mpg..... other than the usual things, tune-ups, air pressure etc.. The best thing that i have seen over the years is an easy pedal. Paying attention to how you drive can really have an impact on your mpg's. When your on the gas.....ask yourself do I really need to be on the gas right now? You'll be surprised at how often your just reacting and stepping on the gas then end up braking instead of just driving at a nice pace. Try it, that's the biggest gain you'll see with mpg's and overall wear and tear.
well the 86 of my dad's is running 31 10.50 R15 but it has a leveling kit instead of a lift kit. as far as the increasing part I don't know we just drive it when needed for work if not needed for work we drive the cheaper on gas suvs.
Trav
You might tweak 1 more MPG if you tinker with it, but like others mentioned it's all in your driving style. If you flog on it constantly it will eat you alive. If you drive like you're afraid of smashing an egg under your foot it will do better.
My '95 did better then my current '89, by 1-2 mpg overall.
I must drive with a light foot compared to some of you guys. My old 89 f150 4x4 with a 5 speed and 3.55 gears got 20 mpg on the highway. In fact I havent had a 302 engine in a truck that was that bad on fuel yet! (my 2 wheel drive with the 3.08 gears and 5 speed got even better!)
With 4 inchs of lift and the MT tires, I wouldnt expect you to get that great of mileage though.
Freightrain really called it best! That or stick a diesel in er
But is that using the US gallon or the silly imperial gallon? You know all these guys are talkin US gallons..
