Welcome IOWA!!!!
Old Oct 5, 2012 | 07:23 AM
  #91
Supercab's Avatar
Supercab
Dave, ARE you running the SYNTHETIC ROTELLA T-6?? if not your engine WILL benefit from it espessely in COLD weather where you are.
IF your fuel filter hasn't been changed in a while you should certainly change it-its simple enough, may be give your fuel system a GOOD STRONG dose of something like Power Service Diesel Kleen-(Double dose a few tanks)
How did you make out with the K rearend?
Old Oct 5, 2012 | 08:35 AM
  #92
iowa 7.3's Avatar
iowa 7.3
thanks
is there a good place to get the
shop manual for the 1999 7.3?
dave
Old Oct 5, 2012 | 09:07 AM
  #93
iowa 7.3's Avatar
iowa 7.3
supercab
the k rearend is fine now!
found out that the u bolts had been jerked loose
the 347 stroker is toooooo much power!!
dave
Old Oct 6, 2012 | 06:41 PM
  #94
iowa 7.3's Avatar
iowa 7.3
i had posted pics on the TPS thread
i cleaned up the IVS n TPS on my truck
and it seems to run pretty good now
as i'm getting good response to accl pedal movement!
will see how long this lasts!
dave
Old Oct 7, 2012 | 06:01 AM
  #95
Supercab's Avatar
Supercab
I think you are doing pretty well now Dave!
How much power is the 347 making?
Old Oct 7, 2012 | 07:32 AM
  #96
iowa 7.3's Avatar
iowa 7.3
we haven't dyno'd it
but the mechanic thinks
right around 400 HP
dave
Old Oct 11, 2012 | 08:33 AM
  #97
iowa 7.3's Avatar
iowa 7.3
just an update
truck starts right up (2nd turn!) and runs great
accl response is great!
to my mom's and back; 200 miles yesterday
and not a blip on the radar screen
cleaning up and blowing out the terminals was the answer!!
will let you know if it goes bad again
hopefully not for another 10 years!
dave
Old Jan 31, 2013 | 01:16 PM
  #98
iowa 7.3's Avatar
iowa 7.3
was looking for a new ford truck for awhile
but have decided my 7.3 is better than their new one's!!
am going to buy a new radio for my 1999 tho
where is a good one to buy that will play mp3's?
thanks
dave
Old Jan 31, 2013 | 01:41 PM
  #99
BigAlsPSD's Avatar
BigAlsPSD
I have a Kenwood, not sure on the model, that plays SD cards, CD's in MP3 format, has auxiliary and USB ports, plays nearly everything. I'm sure most of the modern head units will play multiple formats.
Glad your truck is running well.
Old Jan 31, 2013 | 03:36 PM
  #100
iowa 7.3's Avatar
iowa 7.3
yeah, it's been running great
forgot to plug it in yesterday
and, even tho it was only 20F
it started right up!! (thanks to the new glo-plug relay unit!!)
also, has not died on the road since i had the super chip removed
i did break off the end of the gear shift
(the OD 3 wires were hanging out)
and had a new one put in
but unfortunately they must have forgot to tighen s.t.
as the shifter is loose and hard to get into drive.
i have to go to 1 or 2nd gear 1st and then 'come up' to drive
to get it in
dave
Old Feb 1, 2013 | 03:17 AM
  #101
BigAlsPSD's Avatar
BigAlsPSD
to get it in
dave
Likely the Torx screws at the base of the shifter tube, all that would have been needed to change the shifter is pulling a pin.
Then if your "pointer" doesn't line up after that, you can adjust it with the thumbwheel behind the fuse panel cover on the lower dash.
Old Feb 1, 2013 | 07:41 AM
  #102
Snowseeker's Avatar
Snowseeker
Dave, do you happen to have a couple mustangs? Ever been up to WI? Someone from Iowa came and picked up my 65 notch about 7 years ago and was going to finish the restore.
I still have a 68 in the corner waiting for me.
Old Feb 2, 2013 | 07:06 AM
  #103
Supercab's Avatar
Supercab
Wink
Dave has arusty '65 Fastback K code hes working on, his Son has a '66 (I think) Red coupe.
Old Feb 2, 2013 | 07:40 AM
  #104
Snowseeker's Avatar
Snowseeker
Sounds like the guys that picked up my 65!
Old Feb 2, 2013 | 02:08 PM
  #105
Supercab's Avatar
Supercab
I sold him a fully restored and detailed correct '65 9" rear for his K....then they put it under his Son's restomod Coupe....
Rojak
Jun 27, 2013 10:00 PM
ms_michelle
Large Truck
Jun 26, 2011 12:34 PM
bpounds
S. California Chapter
Nov 24, 2010 12:56 PM
monsterbaby
Iowa Chapter
Nov 2, 2005 01:01 PM
4wd
General Automotive Discussion
20
Nov 1, 2005 09:53 PM
