Welcome IOWA!!!!
i did buy a GPR at NAPA
it's the GPR 110....they looked it up and said it was the right one?
the glow plugs were replaced last fall
so should be good
will let you know what happens
iowa
it has always had the tendency to just 'die' going down the road.
usually it happens about twice per year,
dispite having Ford Co. fix the cam sensor.
now it is happening about every day.
i'll be driving along and it will abruptly 'die'
sometimes, when i go to start it in the morning
the 'wait to start' light will not come on.
i'll shut it off and then usually it does and it will start
whatever the problem is
it's getting worse.
it is a computer thing
or was the cam sensor thing not fixed?
what do i need to do?
thanks
dave
BTW: Hows the Hipo Fastback coming? I sure miss the forum over there!!
Please come and join us at ConcoursMustang Forums - Index -Rick
i'll get the black one!!
what is the link to this Riff Faff site?
'65 HiPo fastback on hold for now
am working on a WWII
piper cub L-4B at the moment
want to get it done this winter
and fly it next spring or summer!!
i'll check out the concurs site
dave(iowa)
but..........
after installing a new cam sensor
i'm still having problems with the truck
'just suddenly dying' while driving it.
i thot the problem was fixed as it went about 500miles
without doing this, and then it started up again.
i'll be driving along and it will drop dead die!!
check engine...wait to start....brake idiot lites all come on.
i've gotten used to this and have become pretty good
about shifting into neutral
turning the ignition key off
and restarting on the move
and it usually starts right up
shift back into drive and continue on my way!!!
could the new cam sensor (from ford) have gone bad?
or is this s.t. else?
iowa
Glad to hear your truck is starting like it should. Makes a BIG difference knowing it'll start for you when you need it!
it just did it again on the way to the airport this am!
this time i went thru the routine as described above
BUT.........
after i shut off the ignition and turned it back on
the 'wait to start' lite would bleek on brief
and then abruptly go off an the truck wouldn't start.
it's like s.t. in the computer system is not allowing
ignition to take place.
after awhile, the 'wait to start' lite came on and
stayed on like it's suppose to
and when it did this, it would start okay.
dave
computer says P0603 which is the cam sensor!!
so, am going to have him put another one in
alsong with the harness and see what happens!
BTW, i'll be hauling back my original Ford,
a 1988 150 4x4 from lincoln this weekend
for my 17 y/o son to drive this winter
IF my diesel isn't having problems!!
dave
mechanic's computer always came up with
the cam sensor and the super chip
that the previous owner had bought and installed for more power.
we decided to replace the sensor and it's harness
and to remove this 'Super Chip'
so far, after about 1000 miles
we're okay no dying!!
course, i don't have that tremendous surge of power
that i used to!!
but if this will correct the problem
i can live with it.
has anyone else had problems with these Super Chips?
iowa
