E4OD I'm lost!!
Old Jun 23, 2010 | 10:09 PM
muff's Avatar
muff
E4OD I'm lost!!
Ok guys I just rebuilt my brothers transmission 1995 f250 E4OD. all forward gears work and shift fine. truck will idle in drive with foot on the brake but when shifted to reverse the engine will stall. it feels like you let out on the clutch and held the brake on a stick. the truck will back up but you have to give it gas and go as soon as you put it in reverse. is it posable that I got a ball bearing in the wrong place or if they gave me the wrong torque converter with the kit could that be it? any help would be great thanks.
Old Jun 24, 2010 | 12:38 PM
muff's Avatar
muff
Ok i have played with this truck some more today and i'm leaning toward a torque converter issue. reverse is same as before stalls on engage unless you give it a lot of gas as soon as it engages so the truck can start moving. i drove the truck around town for about 30 min. it still shifts up and down ok but a few times it stalled when rolling up to the lights. it gave the feeling that i needed to push in the clutch. is there something that could make the t/c act this way or would it be the t/c its self? any ideas would be helpfull thanks.
Old Jun 24, 2010 | 02:47 PM
Lazy K's Avatar
Lazy K
Not an expert but I would think the torque converter clutch is locking up at idle. Maybe because of low line pressure.
Is the fluid level good, should have taken around 16qts to fill it?
If that is OK then I would check to make sure that the fluid filter has not fallen off into the pan. Also if the truck is 4x4 make sure you used a filter for the 4x4 trans.
Old Jun 24, 2010 | 03:20 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
There is a real possibility that it's a 4R70W tranny, NOT a E4OD, if that makes any difference. Have a friend that just made that same mistake!
Old Jun 24, 2010 | 11:19 PM
muff's Avatar
muff
First off thanks for the reply guys. Lazy K the truck is a 4x4 and it did take almost 16 qts. to fill it. i pulled the pan off to check the filter it was still in place i compared the filter to the old one the are the same so no luck there. as far as low line pressure how would i ckeck that?
BPofMD thanks for the reply. i took the trans with me to the supply house to make sure i got what i needed so i'm prety sure it's an e4od.
Old Jun 25, 2010 | 04:12 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...n-reverse.html Have a read here. Especially the posts by Mark Kovalsky.
Old Jun 25, 2010 | 07:47 PM
muff's Avatar
muff
Thanks lazy k for finding that for me. I searched before i posted but i was not as successful as you. i'm going to give that a try i'll let you know.
It's nice to have a guy like Mark here! not to many people can get advice from a guy that helped design the part your working on Thanks!
Old Jun 25, 2010 | 09:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low fluid is the most common reason the torque converter tries to lock in reverse or when stopped in drive.
Encho
Apr 8, 2013 07:52 PM
1979F-150Man
Aug 14, 2011 01:04 PM
Jimkinger
Apr 22, 2009 03:26 PM
joe82ford
Mar 23, 2009 09:41 PM
jeepnford
Apr 1, 2003 10:27 AM
