E4od overdrive troubles
Old Apr 22, 2009 | 03:12 PM
Jimkinger's Avatar
Jimkinger
I have a '93 F150 4x4 with a 302 and the e4od. When the truck shifts into OD the engine labors and the truck slows, (just like the brakes are being applied). Then it will jump back into drive and be fine, until it goes back into OD. If I turn off the OD and drive around in 'drive' its fine. Any idea whats wrong with my transmission?
Old Apr 22, 2009 | 03:19 PM
morse's Avatar
morse
Can you force it to shift into 3rd with the throttle, or can you feel the converter unlock if you hold steady on the gas in overdrive, and touch the brake pedal?
Old Apr 22, 2009 | 03:26 PM
Jimkinger's Avatar
Jimkinger
It feels just like its locked in OD and direct at the same time. If you could lock it into OD and stand on the brakes at 40mph or so, it would feel just like that. As soon as it jumps out of direct and hits OD its slows down and the engine labors. I can get it to downshift if I give it about 1/2 throttle or more. I dont think the converter even has a chance to lock up in OD before the engine labors.
TX92F150
Aug 8, 2013 08:32 PM
coalmanjhj
Sep 18, 2011 07:32 PM
jWoDal
Aug 28, 2011 04:10 PM
peys_daddy08
1978 - 1996 Big Bronco
Dec 27, 2010 11:38 AM
rtpalin
1997 - 2003 F150
May 12, 2008 08:08 PM
