noisy lifters
Old Jun 4, 2010 | 05:59 PM
1973-Big Blue's Avatar
1973-Big Blue
noisy lifters
i have a stock 390 in my f250 and the lifters are pretty damn noisy. how do i eliminate this noise??
Old Jun 4, 2010 | 06:34 PM
NBC-Steve's Avatar
NBC-Steve
That all depends how much you want to spend. The easy answer would be to replace the lifters but if you do that then you should replace the cam and push rods too. And while you are at it might as well do the timing chain also.
Old Jun 5, 2010 | 01:15 AM
1973-Big Blue
there is no adjustment i can make to the rocker arms to quiet it??
Old Jun 5, 2010 | 01:24 AM
Ranchhand96/68's Avatar
Ranchhand96/68
the rocker arms are non adjustable
Old Jun 5, 2010 | 01:50 AM
1973-Big Blue
so lifters a cam and timing chain is the way to go
Old Jun 5, 2010 | 02:13 AM
montana_highboy's Avatar
montana_highboy
You can try to run a quart of MMO or ATF thru it for a few miles.
Old Jun 5, 2010 | 02:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Most FE engines run non-adjustable rocker arms with their hydraulic cams. They are adjustable by installing .060 Longer or Shorter PUSH-RODS.
You'll need to collapse the lifter (which is no small feat with FE lifters) and measure the clearance. The install the correct push-rod whether .060 longer, Stock, or .060 shorter.
Are the lifters noisy all the time or after the engine has warmed up? What weight oil are you running? Have you taken the valve covers off to see if any sludge has built up? The FE engine is very particular about having a clean cylinder head and oil drains.
Josh
Old Jun 5, 2010 | 05:55 PM
smokeyb97's Avatar
smokeyb97
Josh
What would cause the noisy lifters after engine has warmed up . but not when cold?
Old Jun 5, 2010 | 07:14 PM
Bullitt390's Avatar
Bullitt390
1) Wrong weight of oil. For an older, well seasoned engine 10W40 is probably the minimum. Or run Diesel 15W40. A really worn engine may even need 20W50.
2) Worn oil pump, pumps fine with think oil, but can't keep up with hot, thin oil.
3) Worn, collapsing lifters.
Josh
Old Jun 5, 2010 | 08:42 PM
4x4 Bart's Avatar
4x4 Bart
What is your oil pressure when warm???
Old Jun 5, 2010 | 09:06 PM
bamaf150's Avatar
bamaf150
Sorry for hijacking but Bullit mentioned worn oil pumps and my question didnt get answered in another thread but would replaceing the pump in a 360 give better oil psi? When mine warms up the psi gets lowish.
Old Jun 5, 2010 | 09:57 PM
Bullitt390's Avatar
Bullitt390
Might be a band-aid fix to just replace the oil pump.
If it were me and I was tight on funds and wasn't able to do a full rebuild, I would replace the oil pump and while the pan is off anyways try to replace the main and rod bearings as well. I would take into account how well the engine tested for compression and if, if any, oil smoke was present from valve guides or rings.
Josh
300sflyer
Modular V10 (6.8l)
22
Jan 15, 2019 09:11 PM
IDIDieselJohn
13
May 29, 2017 02:45 AM
strat875
Modular V8 (4.6L, 5.4L)
Sep 19, 2016 11:00 PM
Fireman04
Oct 6, 2015 09:26 PM
63maroontruck
Jul 29, 2010 11:49 AM
