02 powerstroke waterpump replacement
Old May 24, 2010 | 02:24 AM
jkarne's Avatar
jkarne
anybody have the instructions to replace a waterpump on an 02 7.3 powerstroke? is it hard or easy!
Old May 24, 2010 | 04:15 AM
Visseroth's Avatar
Visseroth
Yeppers, this one is pretty accurate but you're probably going to need a tool from Napa or some other auto parts store to hold the pulley in place when you go to break the nut for the fan loose. It's a PITA so rent the tool, it's worth it and will save you a TON of trouble.
YouTube - Water Pump RnR
Old May 24, 2010 | 04:25 AM
jkarne's Avatar
jkarne
thanks alot! that is all I need. little brother needs help so i thought i would do some research so i can help him.
Old May 24, 2010 | 04:57 AM
Visseroth's Avatar
Visseroth
no problem. Glad I could help, let us know if there is anything else we can help you with.
Also, keep in mind that it is best to go OEM on these pumps as the aftermarket doesn't seem to hold up. Don't go to the stealership though.
Old May 24, 2010 | 05:22 AM
jkarne's Avatar
jkarne
where could i get the oem for that. i know it isn't a motorcraft part. is it an international part? can i get it from a kragen or napa or somehwhere?
Old May 24, 2010 | 05:32 AM
Visseroth's Avatar
Visseroth
get a hold of Clay at RiffRaff Performance, he can get one out to you. Got mine from him, it's OEM.
http://www.riffraffdiesel.com/mm5/merchant.mvc?
Old May 24, 2010 | 05:36 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Old May 24, 2010 | 10:25 AM
lucaslaw's Avatar
lucaslaw
The guy at powerstrokehelp did have one good idea, if you have an air chisel put it on the nut tilted towards whatever direction it loosens, then buzz it a couple times with it to loosen, a lot easier, and some DONT come with backwards threads, I know, mine didn't.
LL
Old May 25, 2010 | 12:00 AM
Visseroth's Avatar
Visseroth
nor did mine, though not many have a air chisel handy.
Old May 25, 2010 | 10:32 PM
VRC9170's Avatar
VRC9170
I just replaced my water pump with a Napa pump 2 weeks ago. I bought a chain wrench and wrapped it around the pully. I used a pipe wrench on the fan nut and a 3 feet long pipe on it. Held some pressure on the pipe wrench, counter clockwise when facing the pump from the front, and smacked it with a hammer. It loosened right smart like.
It was harder to start the nut when replacing the fan - getting the threads lined up while holding the fan in place seemed to take for ever and my arm started to get tired. But really was only a minute or so.
I have learned a lot from this forum. it is priceless, to say the least, and the following videos on you tube:
http://www.youtube.com/watch?v=bJ3plCTWjLQ
As far as the removal direction of the nut goes, remember this. It loosens by turning it the same direction as the engine rotates when running. That way the nut will not loosen on it's own. The acceleration of the running engine turns INTO the nut and tightens it rather than loosens it.
Bob Bates
Old May 25, 2010 | 10:53 PM
Visseroth's Avatar
Visseroth
Indeed it does. Congrats on the new water pump replacement!
Old May 25, 2010 | 11:55 PM
bluescrew's Avatar
bluescrew
https://www.ford-trucks.com/forums/9...big-day-s.html
heres some photos when i did it
Old May 26, 2010 | 12:38 AM
PaysonPSD's Avatar
PaysonPSD
The fan nut on a 7.3 is the standard righty tighty, lefty loosey.
I borrow the tools from Autozone. I get two different kits. I use the pulley holding wrench from kit 27018 and the fan wrench from kit 27141. The pulley holding wrenches in kit 27141 totally suck. The pulley holding wrench in kit 27018 works like a charm. Ask for both kits and hope they have them.
I get the two tools on the fan nut and pulley at an angle that allows me to squeeze them like the handles on a pair of pliers and the fan nut pops loose.
Old May 26, 2010 | 03:29 AM
jkarne's Avatar
jkarne
hey Payson how did that aircraft engine cleaning solvent work on your engine? or did you try it?
Grease & Gravel
49
Jul 16, 2016 09:05 AM
cmh15
Nov 23, 2015 08:03 PM
MrWillys
16
Aug 3, 2009 03:39 PM
Langford Ford
1983 - 2012 Ranger & B-Series
Dec 13, 2008 08:34 AM
MARC
Mar 3, 2007 08:12 PM
