Waterpump replacement
Old Jul 7, 2016 | 04:26 PM
Grease & Gravel's Avatar
Grease & Gravel
It's time to change the waterpump in my 85' 302. Is there any way to prevent the bolts from breaking, and do they always break or just sometimes? I have been thinking about just taking it to a shop but I don't want to get charged an arm and a leg.
If the bolts do break how hard is it to just take the timing cover off and replace that?
Old Jul 7, 2016 | 05:38 PM
FuzzFace2's Avatar
FuzzFace2
You or the garage you may take it to have a 50/50 chance of something going bad, you never know till get into it.
The way I under stand from another post not long ago when the bolt(s) break that go thru the cover there is no way to get the cover off because the bolt is still in the cover.
So cover cant come off because of the broken bolt and you cant get the broken bolt out so what to do? Bust the cover up to get to the bolt(s) and then get a new cover.
I find that if motors are used all the time (heat/cool cyl) things come apart a little easier.
May want to try and hit the heads of the bolts with a hammer a few times to "shock" the bolt before trying to removing it.
Dave ----
Old Jul 7, 2016 | 05:50 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Corrosion in the cover is not uncommon.
There is really no good way to deal with this *after* it's happened.
I went back with stainless bolts and plenty of Loctite PST to keep coolant out of the threads.
Old Jul 7, 2016 | 07:38 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Originally Posted by ArdWrknTrk
I went back with stainless bolts and plenty of Loctite to keep coolant out of the threads.
You are aware Stainless and Aluminum are incompatible materials ...
Steel 100% coated with Never-seize (except for sealant area) is the correct technique.
-Enjoy
fh : )_~
Old Jul 7, 2016 | 07:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
-Enjoy
fh : )_~
The bolts thread into an iron block.
Chrome nor nickel are any more active than iron in this situation.
(don't bother pointing me at a galvanic nobility chart)
The fact that the shank and threads remain smooth allows them to be withdrawn from the corroded timing case.
I have been there and bought the tee shirt too many times.
Old Jul 7, 2016 | 08:09 PM
Festus Hagen
Methanoholic
Don't worry, I won't!
-Enjoy
fh : )_~
Old Jul 7, 2016 | 09:01 PM
Brnfree's Avatar
Brnfree
Penetrating oil like BP blaster, heat, tapping the bolts with a hammer to shock them, repeat. They also have the freeze stuff in a can. I've never tried it but the idea is to heat the metal around the bolt and then blast the bolt with the freezey suff in a can to shock it.
Only problem with lots of heat is you risk damaging the timing cover gasket.
BTW, how old are your timing chain and gears?
Old Jul 8, 2016 | 06:59 AM
Braggs's Avatar
Braggs
I changed my water pump on my 351W fairly recently and didn't have any problem with any of the bolts. Not sure why everyone's so concerned. No special lubricant was used, just an air ratchet and they came right out.
Old Jul 8, 2016 | 07:21 AM
Franklin2's Avatar
Franklin2
Since the waterpump is pot metal or aluminum along with the timing cover, it's very common for them to get corroded and stuck.
If you get one or two that break off and the pump won't come off, I would get a center punch and try to put a dimple in the center of the broken bolt(this step is important) and then take a drill and drill the bolt out to the depth of the waterpump so it will release the pump. Once you get the pump off, you can deal with the rest of the bolt that is stuck in there, either grab it with pliers or continue drilling with the correct size bit and then take a tap and clean it out. If a garage has to do this you can tell it 's going to take some time and labor is not cheap.
Old Jul 8, 2016 | 02:30 PM
Grease & Gravel
Thanks for all the input. Timing chain and gears are original with 120k miles. Should I just replace those too. Might as well...my timing cover is leaking a little bit of oil so I've decided to go ahead and change that while I'm in there.
Old Jul 8, 2016 | 02:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If your timing set is anything like mine was, it is overdue @ 120k
Old Jul 8, 2016 | 02:53 PM
Festus Hagen
Methanoholic
302 uses a Plastic (Non metallic) sprocket?
-Enjoy
fh : )_~
Old Jul 8, 2016 | 03:33 PM
iwals's Avatar
iwals
I replaced my water pump on an '86 302 a few years ago. No problem I remember getting bolts out. The big headache was pretty much each bolt is different and there are a lot of them. You need a system to keep them straight. I stuck mine in a foam block for safekeeping, if I remember. Also, the water pump bolts go through the brackets of pretty much everything bolted onto the engine: power steering pump, A/C compressor and alternator.
Regarding the timing chain, mine went bad at about 115K. If you're up to it, it might be good to replace it too while everything is off.
Old Jul 8, 2016 | 05:43 PM
Franklin2's Avatar
Franklin2
I definitely think it's a good idea to replace the timing chain. If you are going to do this you need to go buy a puller made to pull the balancer off, they have them at most auto stores. But the hardest part is getting the timing cover separated from the oil pan. I ended up loosening the oil pan up and letting it drop just a little bit before I could get the cover off. Cut the oil pan gasket clean with a knife and use some rtv to splice it back together. The timing cover gasket cover kits come with new oil pan gasket pieces to splice back in.
P.S. Also check the balancer when you take it off. It may have a deep groove worn in it where the seal rides. If it does they make sleeves that you push over this area to make it smooth again. Even though it's a little bigger, the original seal still works. Putting a new seal over the groove without repairing it usually ends up with a oil leak.
Old Jul 8, 2016 | 06:42 PM
ctubutis's Avatar
ctubutis
-Enjoy
fh : )_~
Ford used nylon-coated gears in certain applications to reduce noise.
