Correct transmisison fluid?
Old May 12, 2010 | 03:51 PM
banjopicker66's Avatar
banjopicker66
My book for my 2000 says to use Mercon, for my original automatic transmission. Not sure which tranny I have - can I use Mercon V, or if not, which one?
Thanks in advance!
Old May 12, 2010 | 06:17 PM
clintbonnie's Avatar
clintbonnie
Mercon or Mercon V will work... You have a 4r100 trans..
Note: your power steering also uses Mercon, but alot of us have switched to Mobil 1 syn.
Old May 12, 2010 | 06:32 PM
Izzy351's Avatar
Izzy351
I would suggest Merc V. Ford stopped licensing Merc, so who knows what it really is. I'm running syn Merc V (Mobil1 ATF) and my trans is still quite happy. Even swallowing ~500 HP from the crank. LOL
Old May 12, 2010 | 11:19 PM
DND58's Avatar
DND58
Questions. If you're changing from Merc to MercV, do you use Marks procedure as written? Do you need to push any extra fluid through, or is any mixing a non issue?
Old May 13, 2010 | 01:30 AM
bluescrew's Avatar
bluescrew
what is marks procedure?
Old May 13, 2010 | 01:51 AM
Stewart_H's Avatar
Stewart_H
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Stewart
Old May 13, 2010 | 05:00 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Use it as written. You don't need to do anything extra when changing from MERCON to MERCON V.
Old May 13, 2010 | 12:22 PM
bluescrew's Avatar
bluescrew
ok i just read marks procedure, i get lost when he talks about hooking up clear tubing.. cant i just drain the pan, clean it out, then fill it back up.. please explain for me.
thanks!
Old May 13, 2010 | 05:53 PM
clintbonnie
If you do just the trans pan.. you are leaving about half the dirty oil that is in the torque converter.
Pitcrw6
Mar 13, 2011 06:22 PM
UNTAMND
18
Aug 31, 2010 11:53 AM
JFUSION
Escape & Escape Hybrid
Nov 21, 2006 08:34 AM
TallPaul
Oil & Lubrication
Jun 1, 2004 06:07 PM
chrison600
Apr 29, 2003 01:09 AM
