The feed to the GPR is on the wrong side of the relay.
x2 above. Move the large Red-Orange wire to the other terminal where the other two large wires are at, bottom photo. The way it's hooked up now the glow plugs would only have power during cranking.
swapped the orange stripe wire...now when key is at "on" the gpr has a faint but audible buzz that stops after a min or 2...is this how it should be???
