Early Model Dana 60 swap problems!
Old May 5, 2010 | 10:54 PM
slwsmkn444's Avatar
slwsmkn444
I just swapped a dana 60 rear axle into my 96 250. Its out of a 78 F250 rig. It doesnt have a VSS sensor-Question: Am I screwed? what can I do? My ABS light is on, no speedo, and trans shift is like limp mode! Any help would be great, gotta go to work in about 12 hours and need a ride! lol thanks guys
Old May 5, 2010 | 11:33 PM
Neal 97 250's Avatar
Neal 97 250
my first though is screwed.
Sorry crude but well....
second thought is why did you do the swap? the sterling you just removed is a good strong axle.
Third though is you might be able to make it work. you will need the vss to get the tranny to shift correctly and to get the speedo to work. Maybe you can get the sensor to work in the older axle. Just a thought.
Old May 6, 2010 | 07:30 AM
slwsmkn444's Avatar
slwsmkn444
Thats kinda what i thought too. I dont know how to make the sensor work in the old axle without drilling into the pumpkin and it would be a lot easier to just swap back to the sterling. I lifted the truck and the old axle has the right gear ratio and lockers already, mine is to tall of gears for the tires and is open diff. Oh well guess its time to spend some $$. Thanks Neal
Old May 6, 2010 | 09:16 AM
Talyn's Avatar
Talyn
They put open 10.25's in?
I guess anything is possible.
I think you woulda had better luck swapping in carriers than a d60.
My only thought is to put the VSS into the hub, but if there is nothing in there for it to read, it wont work either.
Old May 6, 2010 | 10:50 AM
Brown Falcon's Avatar
Brown Falcon
Definately swap back to the 10.25
Old May 6, 2010 | 02:52 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Yes they did William, remember I told you mine is UNLIMITED SLIP... its open WIDE OPEN XD
Old May 7, 2010 | 05:58 AM
Brown Falcon
So is mine... one tire fire!
Old May 7, 2010 | 07:16 AM
Talyn's Avatar
Talyn
Sorry guys.
I shoulda thought about that on 2wd's.
DOH!
Old May 7, 2010 | 09:50 AM
Neal 97 250
They put open diffs on 4X4's also. The truck I about bout new was just like mine but two tone red/white and had 3.55's and an open diff.
Glad I went with the red one. LOL
Old May 7, 2010 | 10:21 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Mine's as open as they come. One tire fire indeed!
Old May 7, 2010 | 10:47 AM
Talyn's Avatar
Talyn
Excuse my stupidity. I really should know better on that one.
sand1
Mar 23, 2015 08:16 AM
thewestie
43
Jul 21, 2014 07:50 AM
Dirtyweekender77
Nov 10, 2013 07:51 PM
96dana60swap
Sep 29, 2011 01:53 PM
88bronco351
Offroad & 4x4
Feb 2, 2006 02:38 PM
