I have a '95 PSD f250 4x4 SC....I bought this truck 1.5 years ago...it came to me in a non-start when cold condition...swapped out GPR and glo-plugs...still no start...read here and there for days and figgered the injector poppet valves must be worn...today...just cos I actually felt good enuff to get under the hood...I took my multi-meter to the GPR...no power to either big post with Key Off...with Key On no power to either post...seems I have a break somewhere in the GPR to solenoid harness...any help/experience on a simple almost painless fix????
One of the big posts should be hot all the time, Blk/Org on mine. If you follow it I believe it goes over to the starter relay on the passenger fender. Also there are two fuse links somewhere in the wire.
I have power to solenoid...no power to either GPR post...is that GPR to solenoid wire a seperate wire...or does it connect to other parts of the electrical...appreciate the responce...
mojo
It's a separate wire. You can make up a temporary jumper wire from the starter solenoid to the GPR (hot) terminal and see if it works. If so then fuse links are probably blown.
well...I built an 8 gauge temp connecting wire...unplugged old wire and hooked up new wire...good news is there is 12 volts to GPR....bad news is when I turn the ignition to "ON"...not "Start"...the truck starts on its own and the starter stays engaged...I caught it fast enuff to not burn the starter out....I hope...any ideas???
Sounds like your backfeeding your starter relay. Locate your starter relay on the top left (pasenger side of the truck) If you ran a jumper wire to the GPR pull both batts negative wires and then remove that jumper. Then look over your starter relay near the coolant tank on top of the fender.
I think that there are a couple of fusable links somewhere there and maybe you shunted around it with the new wiring sending power directly to the starter.
I connected the temp wire to the front side of relay...the side that has 12V always...basically replaced the wire in the same position as the original...it wasn't hard to trace back...now I'm back to pluggin' it in....grrr
