Gpr or flow plugs?
Old Aug 18, 2016 | 02:02 PM
sudsmcduff's Avatar
sudsmcduff
Gpr or flow plugs?
My truck just started taking 4-5 seconds to fire up. But still starts every time. Do I bother testing gpr? I can't find a post on bad gpr symtoms. Thanks
Old Aug 18, 2016 | 02:20 PM
knottyrope's Avatar
knottyrope
You can ohm out the glow plugs at the UVCH plug and then see from the controller if there is 12v being supplied from that connector
Old Aug 18, 2016 | 02:27 PM
Walleye Hunter's Avatar
Walleye Hunter
At these temps I don't think that glow plugs will be the issue but I have the same problem and would like to hear what you find.
Old Aug 18, 2016 | 02:34 PM
knottyrope's Avatar
knottyrope
Vallejo had some 54 degree mornings coming and that might need the GP to work right
at 70 I don't wait, just crank it over with out issue just like I have done on my diesel tractor for past 10 years.
If the starter is getting weak and slower, it might not get enough cylinder pressure to combust the fuel
worn injectors can retard the timing and make for a hard start but test the GPs first and let us know the temp you were trying to start it at
Old Aug 18, 2016 | 02:42 PM
z31freakify's Avatar
z31freakify
Bad injectors can cause hard starts , it could be 100° outside and still won't start.
Old Aug 18, 2016 | 02:47 PM
sudsmcduff's Avatar
sudsmcduff
Ok. Will test glow plugs when off work
Old Aug 18, 2016 | 04:01 PM
sudsmcduff's Avatar
sudsmcduff
All glow plugs have resistance. All at .5 to .6 except second plug from rear on passenger side. Was at around 26.0. I guess that's the culprit. Runs fine as well once started. Motor cranks normally. Just takes those extra seconds to fire up.
Old Aug 18, 2016 | 04:52 PM
HKusp's Avatar
HKusp
1 plug shouldn't slow that thing down a bit. Something else is going on.
Old Aug 18, 2016 | 04:55 PM
sudsmcduff's Avatar
sudsmcduff
No engine light or codes. Batteries 2 years old. I wil
Google how to check gpr and see what comes up.
Old Aug 18, 2016 | 05:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
i always put a light on the outlet of the glow plug relay. i have started using 12 volt LED's the past year. this rules out any question whether the relay is working or not. .if the LED/light comes on, the relay is working.
the dash wait to start light will come on for 15 seconds or so whether the relay is working or not. with the added light, you will see the glow plug relay actually sends power to the glow plugs for up to 2 minutes.
Old Aug 18, 2016 | 05:42 PM
Jaime74656's Avatar
Jaime74656
Not trying to hijack but I been wanting to do the GPR light mod and was curious if we have a wire schematic or Anything like that posted up to here?
Old Aug 18, 2016 | 06:28 PM
hydro man 17's Avatar
hydro man 17
Signature states Vallejo ( CA.?) = GPCM, different ball game. Need to check for power to each GP, or could be a whole bank.
Old Aug 18, 2016 | 06:32 PM
sudsmcduff's Avatar
sudsmcduff
Where is gpcm located?
Old Aug 18, 2016 | 06:55 PM
sudsmcduff's Avatar
sudsmcduff
With ignition off I get battery voltage on positive side of relay. But I get 37.7 volts off the other side of relay with ignition off. With key on I get batt voltage on batt side post and 9.62 volts on other side big post.
Old Aug 18, 2016 | 08:06 PM
HKusp's Avatar
HKusp
Do you have the glow plug relay or is your truck an original California truck with the GPCM?
If a relay equipped truck check this thread. lots of good stuff from Roland and Rich about testing the relay.
https://www.ford-trucks.com/forums/1...y-strange.html
