gpr-109 installed got question
Old Nov 4, 2014 | 07:10 PM
mybigredford's Avatar
mybigredford
installed a gpr-109 today and truck starts, except when turn the key and power it up I get the click but it also buzzes for the duration of the cycle. is this normal for the gpr-109 or did I get a faulty one?
Old Nov 4, 2014 | 08:24 PM
petrokiller's Avatar
petrokiller
I never here anything from my gpr109 until it cycles off. I really have to listen for that.
Could you be hearing the vac pump priming up?
Do you have gpr led installed?
Old Nov 4, 2014 | 08:33 PM
mybigredford
Nope it wasnt the vaccum priming up, definatly the gpr, you could feel it vibrating as well, napa is ordering me a new one
Old Nov 4, 2014 | 08:38 PM
whitetmw's Avatar
whitetmw
Solenoids are nothing more than Relays which are beefier. Buzzing or vibration indicates the magnetic field is not steady. This could be due to a loose wire, wire end, wire connector bolt, chafe, bad ground, or the solenoid itself.
Just give you're wiring a good look-see and make sure that ground is clean and not corroded or overly dirty.
Old Nov 4, 2014 | 08:42 PM
mybigredford
All connection at the gpr were nice and clean, i even took some emery cloth and cleaned them up more before installing the new gpr . guess i will see what happens with the new one, where is the ground for the gpr? Grounds when you bolt it to the engine?
Old Nov 4, 2014 | 08:56 PM
whitetmw's Avatar
whitetmw
That's correct
Old Nov 4, 2014 | 09:01 PM
mybigredford
Thats one part i didnt check and clean up .
Thankss i will clean it when i get the new one
RustyTank
Jun 13, 2019 02:44 PM
amsetikas
Aug 28, 2017 11:12 PM
frdf250
May 29, 2015 01:30 PM
bkuuz1
Oct 2, 2014 09:23 AM
rmalottwtes30
Mar 9, 2008 08:39 PM
