What causes high EGT's?
Old Apr 6, 2010 | 06:46 PM
Izzy351's Avatar
Izzy351
So you fixed it? A loosy-goosy wastegate is ALSO an exhaust leak. So when you have low boost/high EGTs, that's the first place to look, given you nave *known good tuning*.
Black smoking can happen, but the worse the leak, the more the smoke.
Old Apr 6, 2010 | 06:47 PM
beanhead6D5's Avatar
beanhead6D5
I will be working at home this weekend Casper.If you want to make a road trip we could get her in the shop for a look over.
Like these guys said,start with looking for leaks.
EDIT: I see you got it!
Old Apr 6, 2010 | 06:48 PM
superduty4x4's Avatar
superduty4x4
You two Joes (CSIPSD and Izzy351) just quit beating around the bush and come out with it...
BANKS POWER FTW!
Old Apr 6, 2010 | 06:51 PM
Izzy351's Avatar
Izzy351
BANKS POWER FTW!
Get outta here and stop stirring up trouble, OBS boy.
Old Apr 6, 2010 | 06:53 PM
CPUNeck's Avatar
CPUNeck
I wish man, that was how bad the turbo was when I installed it last summer.
So is it time to give Gale a call.
Old Apr 6, 2010 | 06:54 PM
superduty4x4
I have the right to troll still since I haven't picked the OBS up yet Once I get it, I'll put my self imposed ban for this forum on and never return so that the party can finally commence
Old Apr 6, 2010 | 06:57 PM
CPUNeck's Avatar
CPUNeck
RE-EDIT: Not quite.
Heck, I might be up for a little road trip anyway. I need another 1/8" on the pinion (Andrew's adjustment made a pretty big difference) and even though he may not be there... between the two of us I'm sure we could turn it that much.
Old Apr 6, 2010 | 07:16 PM
beanhead6D5
Lol,and that was just finger tight for Andrew.Thats allright if we can't get it I have a 1" impact that will.
Old Apr 6, 2010 | 08:30 PM
spdmpo's Avatar
spdmpo
Originally Posted by CSIPSD
There are a ton of things that effect EGT's... but I cant talk about them...
In all seriousness I don't see why you couldn't, this isn't about DP or anything related; and I'd like to hear what those things are, other than what we know is obvious about your feelings.
CPUNeck, so what exactly did you find out?
Old Apr 6, 2010 | 08:57 PM
CSIPSD's Avatar
CSIPSD
Honestly... If I want to remain unbanned I cant. Has nothing to do with any specific tuner, someone else can chat about it.
Old Apr 6, 2010 | 08:59 PM
spdmpo's Avatar
spdmpo
Fair enough, I'll let it go then.
Old Apr 7, 2010 | 11:16 AM
CPUNeck's Avatar
CPUNeck
Well looks like I might be making a trip to my new found MO friend, Brad (who happens to be an up-pipe expert according to Andrew ) and install some new dough nut gaskets and check the rest of the intake for leaks. Weather is kinda nasty today, but if I get out of class in time, I'm going to get my inspection mirror and give the ol' babies but a going over.
Old Apr 7, 2010 | 06:59 PM
  #28
beanhead6D5
UPPIPES As long as there not like Andrew's.
Also check were the turbo and the spider go togeather.I didn't have mine line up right and had a boost leak there.
Old Apr 7, 2010 | 07:21 PM
  #29
Izzy351's Avatar
Izzy351
Yeah, I had the same problem, Brad. When I swapped compressor housings, it LOOKED like the spider & turbo were aligned, but I was only getting about 22psi. Built myself a leak tester and found it right away...
EDIT: And the 38r housing can be indexed, so make sure it's lined up correctly.
jethrodean
6.7L Power Stroke Diesel
30
Mar 24, 2017 06:23 AM
jayhawk714
Feb 12, 2017 04:35 PM
akblackfoot
Jul 6, 2016 12:08 PM
akblackfoot
Jun 21, 2016 07:47 AM
dmanshane
39
Nov 23, 2014 01:25 AM
