dp mount
Old Sep 29, 2011 | 08:58 AM
  #46
Mike F250's Avatar
Mike F250
I mounted mine in the bikini hook. Cut and shaped with a plastic welder. Only down side is it's hard to see the display. But, I only change settings when I tow or set to stock for cold cold starts.
Old Sep 29, 2011 | 11:00 AM
  #47
DemonRace6's Avatar
DemonRace6
Hi!
I wish I could post up a pick. DP will not be in my truck till some time next year.
I think I like it mounted to the right of the steering wheel the best. Looks OEM
Old Sep 29, 2011 | 12:06 PM
  #48
Bpayton's Avatar
Bpayton
I just did mine over lunch I think it looks good.
Old Sep 29, 2011 | 09:54 PM
  #49
Ponyboychris's Avatar
Ponyboychris
Here's mine.
Old Sep 30, 2011 | 06:23 AM
  #50
Rose Clifford's Avatar
Rose Clifford
just make sure you sit in the seat during a sunny day and can see it where you want to put it. next to the steering wheel is a good spot, but I can't see mine where I put it unless i move to the left or right a little. Also, take future gauge additions into consideration. You might not want to mount it in a center location of open space in case you need that space later....keep it up tight to other switches, etc and leave as much open space for additional items as you can.
Old Nov 20, 2011 | 03:50 PM
  #51
honeydew's Avatar
honeydew
My DP tuner switch mount used to be around one of the gauges on my 3 gauge under dash pod. Just switched to a 4 gauge pillar mount and didn't really want the DP switch up there. Found that the gauge ring fits perfectly sandwiched between the base and phone specific mount on my proclip setup. Pic on phone shows the mount before I reinstalled the cradle onto the ball swivel. Works well, I'm very pleased with this setup.
Old Nov 20, 2011 | 05:51 PM
  #52
Tugly's Avatar
Tugly
I just finished the last of the installs this month.
Old Nov 20, 2011 | 08:04 PM
  #53
Stewart_H's Avatar
Stewart_H
Hah! Travis, I love the PiP shot!
Stewart
  #54
Stewart_H's Avatar
Stewart_H
Double post.
FTE is stuttering tonight.
kyle j
Jul 6, 2017 04:44 PM
runamuckr
Jan 2, 2017 04:24 AM
triskit16
64
Mar 25, 2009 03:28 PM
Intense_Spence
35
Jan 25, 2009 04:23 AM
MallardSlayer07
19
Oct 8, 2007 10:46 AM
