Boredom Thread
Old Jun 21, 2010 | 05:54 PM
  #151
460/5's Avatar
460/5
Zombie Survivalist
well, today i seafoamed the ol exploder. im fairly certain that the whole town thinks it actually exploded. 225,000 miles worth carbon just got burnt out. . dunno if i have any real gains yet as it was still smokin when i parked it again, so it can soak overnight a little and get some more out.
Old Jun 21, 2010 | 06:53 PM
  #152
mattthegreat's Avatar
mattthegreat
hey can you explain what it is you did? get rid of carbon? i thought only those ("special") gasoline's or additives removed carbon build up.
maby I have this wrong.
Old Jun 21, 2010 | 07:08 PM
  #153
460/5's Avatar
460/5
Zombie Survivalist
just add some seafoam man.
heres the web page for the motor treatment stuff like i used. complete with a vid. if you want, send me a PM, and when i get a camera, ill be sure to take a video. i think its hilarious when i use the stuff, and its an old car, so it could probably use a second helpin of it. lol.
Sea Foam | How to Use Sea Foam Motor Treatment
Old Jun 21, 2010 | 07:16 PM
  #154
460/5's Avatar
460/5
Zombie Survivalist
i might add that i use the whole can on the intake. i just stick a hose on an open vacuum port and stick the hose in the can. let it suck enough to die. let it sit for about 5 minutes, and then drive it around for another five. make sure its warmed up before you start the procedure as well. i like to drive till the smoke starts to thin, but isnt gone, and then park it. let it sit overnight and soak some more, then it will get cleaned when i drive the next day.
first time ive done it to this vehicle, but ive done it to my others and it really makes a big difference.
Old Jun 21, 2010 | 09:55 PM
  #155
mattthegreat
cool looks much better than all the other cleaners, I can actualy see something happening.
Old Jun 21, 2010 | 10:19 PM
  #156
FordNFishinLover's Avatar
FordNFishinLover
Does it work just the same as if you threw it in your gasoline??
Old Jun 21, 2010 | 10:31 PM
  #157
FordNFishinLover
Can i use any vaccum line to do the seafoam? Most videos ive seen says to suck it through the brake booster line?
Old Jun 21, 2010 | 10:51 PM
  #158
460/5's Avatar
460/5
Zombie Survivalist
this is one guys vid on it. ive done it through the vacuum tree, and strait down the intakes before too. on carbed rigs, you can just poor it in the carb.
YouTube - Seafoam How To 1996 Ford Explorer 5.0
i used the whole can in the intake, none in the oil or gas. i use lucas pretty much everything, and seafoam as a carbon cleaner. if its just in your gas, it will clean the system. but it wont smoke, and i wont do as good of a job in my opinion at gettin all the crap out. all that white smoke is the carbon and gunk in your motor gettin burned off and blown out.
Old Jun 21, 2010 | 10:52 PM
  #159
newrider3's Avatar
newrider3
You can just dump it straight down the carb, that's what I did for mine.
edit: 460/5 beat me to it.
Old Jun 21, 2010 | 11:03 PM
  #160
FordNFishinLover
So just drizzle around 1/2 bottle of seafoam down the carb slowly while its in idle until it dies? I got two bottles, so im thinking of throwing 3/4 into oil, 1/2 into carb, and 3/4 into gas. Think that should get a pretty good overall cleaning?
Old Jun 21, 2010 | 11:07 PM
  #161
mattthegreat
I am a little conserned about something i read about this, in old vehicles carbon build ups are holding the old seals together and preventing leeks, have you ever expierieanced this, old seals breaking down and leeking?
Old Jun 22, 2010 | 06:05 PM
  #162
mattthegreat
hey, couldent find sea foam but the guys at the shop know what it is, they say that it is probobly not available in canada, next time I go to the states I will stock pile. any ways they told me to try this stuff, only 12$ so what the heck, it is gunk motor flush, supposed to be put into a cold engine gun at idle for 5 minuts then change the oil, have no idea if this works, any one tryed it?
Old Jun 22, 2010 | 08:03 PM
  #163
460/5's Avatar
460/5
Zombie Survivalist
as far as causin the seals to leak, ive never experienced it cause of the seafoam. if i have leaky seals its cause the motor is wore plumb the hell out, not from loosened carbon buildups...
that sucks that you cant get it in canada... and gunk works pretty good too. the "cure all" additives and cleaners i trust include: lucas (for any, and everything), WD40, seafoam, gunk, and pretty much any kind of brake cleaner.
FNFLover, i think that should work. only i would do half of one in the oil, the other half in the gas, and one whole bottle in the intake. but thats just me, do it how you see fit. thats the beauty of it.
Old Jun 23, 2010 | 12:00 AM
  #164
76f350spercamprspeal's Avatar
What....? I was Bored...
Old Jun 23, 2010 | 12:55 AM
  #165
Fordzilla80's Avatar
Fordzilla80
I love the truck on the front of the 4 wheeler brochure.I bet it has a black interior too.
