So I've replaced the sway bar bushings, and the end links and now I'm tackling the Body Mounts. Great directions, unfortunately, I got the bolt out, threaded it back in 1/2" but after tapping, hitting, and pounding the snot out of it, I cant get the bottom rubber to separate from the top, on either the driver or passengers side . Also, strange, the driver side bolt was 15/16, but the passenger side was 13/16....Any suggestions???
BigGreenTowMachine
2002 Excursion Limited V10
2007 BMW 335i Sport
BigGreenTowMachine
2007 BMW 335i Sport
Mine were different driver to passenger side also. I wonder if we are the few out there with original bolts or something...
How many body mount did you guys take loose to pull the ones under the front seats? I took both fronts loose and I could not get the body high enough to remove the top bushings?
